Muon power settings question
I'm having a sort of an issue with power settings on a Muon.
Scenario:
1- I remove the battery of a Muon to start fresh
2- replace the battery
3- set the power config via SystemPowerConfiguration.powerSourceMinVoltage(5080)
4- read via pmic->getInputVoltageLimit()
5- settings are not set
Now if I:
3- set the power config via pmic API
4- set the power config via SystemPowerConfiguration.powerSourceMinVoltage(5080)
5- read via pmic->getInputVoltageLimit()
6- settings are set
What am I doing wrong? Maybe a config set with power manager cannot be read with pmic calls?
How would I verify that settings are correct with power manager?
set power config using SystemPowerConfiguration
SystemPowerConfiguration *powerConfig;
    uint16_t currentLimit = pmic->getInputVoltageLimit();
    logp.info("Current input voltage limit: %u mV. Attempting to update to %u mV.", currentLimit, desiredLimit);
        System.setPowerConfiguration(SystemPowerConfiguration()); // To restore the default configuration before making changes
        powerConfig->powerSourceMaxCurrent(900)
            .batteryChargeCurrent(1024)
            .batteryChargeVoltage(4208)
            .feature(SystemPowerFeature::PMIC_DETECTION);
        int res = System.setPowerConfiguration(*powerConfig);
        Log.info(" * * * * * power config API MODE setPowerConfiguration=%d", res);
        if (currentLimit == desiredLimit)
         Log.warn("Attempt %d: Failed to update input voltage limit. Current limit: %u mV.", attempt, currentLimit);
set power config using pmic api:
    powerConfig->feature(SystemPowerFeature::DISABLE);
        WITH_LOCK(*this)
            pmic->begin();
            pmic->setInputVoltageLimit(5080);
            pmic->setInputCurrentLimit(150);
            pmic->setChargeVoltage(4208);
            // pmic->setChargeCurrent(0, 0, 1, 0, 0, 0);
            pmic->setChargeCurrent(10);
            pmic->enableCharging();
            pmic->enableDPDM();
            pmic->enableBuck(); // Neat trick to force System Power Manager to run DPDM.
"Failure" logs via SystemPowerConfiguration:
0000004042 [power] INFO:  * * * * * power config API MODE setPowerConfiguration=0
0000004053 [power] INFO: Current input voltage limit: 4360 mV. Attempting to update to 5080 mV.
0000004671 [power] INFO:  * * * * * power config API MODE setPowerConfiguration=0
0000005679 [power] WARN: Attempt 1: Failed to update input voltage limit. Current limit: 4360 mV.
0000006355 [power] INFO:  * * * * * power config API MODE setPowerConfiguration=0
0000007359 [power] WARN: Attempt 2: Failed to update input voltage limit. Current limit: 4360 mV.
0000007990 [power] INFO:  * * * * * power config API MODE setPowerConfiguration=0
0000009010 [power] WARN: Attempt 3: Failed to update input voltage limit. Current limit: 4360 mV.
0000009626 [power] INFO:  * * * * * power config API MODE setPowerConfiguration=0
0000010630 [power] WARN: Attempt 4: Failed to update input voltage limit. Current limit: 4360 mV.
0000011273 [power] INFO:  * * * * * power config API MODE setPowerConfiguration=0
0000012278 [power] WARN: Attempt 5: Failed to update input voltage limit. Current limit: 4360 mV.
0000012281 [power] ERROR: Failed to update input voltage limit to 5080 mV after 5 attempts.
Success logs if I use both modes to set power settings:
0000003370 [power] INFO: Current input voltage limit: 4360 mV. Attempting to update to 5080 mV.
0000004057 [power] INFO:  * * * * * power config PMIC MODE
0000004711 [power] INFO:  * * * * * power config API MODE setPowerConfiguration=0
0000004814 [power] INFO: Input voltage limit successfully updated to 5080 mV on attempt 1.
Setting the parameters with setPowerConfiguration is asynchronous. At some point in the future the settings will be changed, so reading the state back immediately won't show the change.
