I'm moving over a setup I have on a Boron to the Muon, where it was working great on the Boron using the 3v and 5v output pins. For the Muon, I have setup a new Muon using the Dev Board, and am powering the board with 12v in via the screw terminals. I did the setup via setup.particle.io, which I understand should configure the 3v3 aux to be available.
I'm not seeing any voltage from pins 1 (3v3Aux), or pins 1 or 4 (5v) on the dev board (directly measuring on the 40pin header). Did I configure something incorrectly? Thanks.
