I've been testing out some M404's with the Muon carrier, and I've noticed that the "power" diagnostics are not working properly for me.
I have a lipo plugged into the battery port, and a 6V panel into the DC in port.
The charge light is illuminated.
Here are the values from the spark/device/diagnostics/update
payload:
"power":{
"battery":{
"charge":{
"err":-210
"state":"unknown"
"source":"unknown"
I also get zero's when I use the great DiagnosticsHelper library from RK:
PowerSource = DiagnosticsHelper::getValue(DIAG_ID_SYSTEM_POWER_SOURCE);
BatteryState = DiagnosticsHelper::getValue(DIAG_ID_SYSTEM_BATTERY_STATE);
Reading the battery voltage works as expected, however the SOC value is -1.
FuelGauge fuel;
BattV = fuel.getVCell();
BattSOC = System.batteryCharge();
I recall reading somewhere that I may need to tell the Muon that we have the PM-BAT module attached, is that what I'm missing?
