I’m really having a difficult time with my Electron. Just getting it into Safe mode with the breathing Magenta is a hassle. Slow flash cyan, fast flash cyan, some red, some orange, it takes forever and I have 5 bars when I place it just right on the table. Finally breathing purple! Now to send it 1 sketch OTA. Takes 10 tries now even when it’s in safe mode. I wanted to eliminate the possibility my code is causing a problem. Still I get a few cyan blinks, instead of the magenta it is supposed to do when it’s successful. Finally. So I run my code which uses some data, which knocks out the USB. Have to unplug and replug real fast or I’ll miss it. The fix is coming in 0.5.0? Now I’m leaving 30 seconds delay after data, to give me time to reconnect USB and click on connect. Still things get weird, I have to try the reset button. Sometimes that doesn’t even work I have to unplug the battery. I know it’s not my code because system mode is automatic, which means my code hasn’t even started yet after reset. It seems like the modem gets in a different state until you unplug the LiPo. In fact that must be the case, as reset seems to reset the processor completely. All this debugging, which has nothing to do with my code, uses data! Even if I upload locally. I’ll keep at it. Any suggestions?
I can hear over my unconnected speakers clearly every time it sends data. Sometimes it’s flashing cyan, slow or fast, and not even trying. What’s it doing?
