Sparkcore slowly breathing white
After a factory reset the led is slowly flashing white.
Resetting again, all is normal up untli the mode button is released and the LED should flash blue, but slowly flashes white instead.
Terry
Was it working before? Breathing white indicates that the core is having difficulty communicating with the CC3000 module.:smiley:
for the reply
It would enter the blue flashing mode and allow me to set the SSID etc
and would flash green, but not connect. It is a brand new device.
Terry
It’s not entering now I guess?
i can reset so it blinks green then
dfu-util -d 1d50:607f -a 0 -s 0x08005000:leave -D cc3000-patch-programmer.bin
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Filter on vendor = 0x1d50 product = 0x607f
Opening DFU capable USB device… ID 1d50:607f
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/20001Ka,108001Kg"
Claiming USB DFU Interface…
Setting Alternate Setting #0
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
No valid DFU suffix signature
Warning: File has no DFU suffix
Downloading to address = 0x08005000, size = 51548
when I reset it stlll blinks white
Sorry cut the paste short. Should have been
dfu-util 0.7
Opening DFU capable USB device... ID 1d50:607f
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash  /0x08000000/20*001Ka,108*001Kg"
Claiming USB DFU Interface...
dfuIDLE, continuing
File downloaded successfully
Transitioning to dfuMANIFEST state
Error during download get_status
Tery
Try performing a factory reset again and let it sit awhile if it still breathes white.
ok I’ll leave it an hour
Still breathing white after an hour.
Looks like I have an expensive flashing LED.
Promised so much.
Hey @Terry,
We can get it replaced as it seems like the core ended up defective during the shipping journey.
Every single core that is manufactured undergoes full testing and certified passed before ending up in inventory.
@tavares and @will need you guys to assist on this!
Thanks @kennethlimcp
@Terry can you please go to our support site and open a ticket so we can get your contact information and a bit more diagnostic information?
@Terry +1 for @tavares’ comment–we’ll get you sorted out. Sorry for the problems you’ve been having :frowning:
