I’ve had my Spark for a few weeks and it was working fine up to last night. Now it is pulsing/flashing white/cyan but not going online, listening, or communicating with me via serial or cloud.
I haven’t been able to get it back into listening mode, so I think that prevents me from connecting via serial.
I did manage to use dfu-util to connect and flash it (below). After flashing (deep update 2014 06), it looks like it is breathing cyan, but still is not connecting. It seems like DFU mode is the only way I can communicate with it.
Apologies but cyan and white look pretty similar to me so I may be mixing up the colors…
After factory reset - flashing white
After restart - flashing white
After deep update - breathing cyan
After restart - breathing cyan
After I press Mode - solid cyan
Invalid DFU suffix signature
Opening DFU capable USB device…
ID 1d50:607f
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
Downloading to address = 0x08005000, size = 93636
Download [=========================] 100% 93636 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Thanks that was a good tip - but unfortunately it didn’t resolve it.
The flash command executed ok, and the spark started blinking magenta, but it never stopped blinking (over 1 hour later). I re-tried a couple of times but got the same result.
Other attempts:
I flashed factory_firmware.bin (worked) and then cc3000 (failed, as before)
I flashed deep_update_2014_06.bin (worked) and then cc3000 (failed, as before)
So it seems that my cc3000 is unhappy about life. Is there any other way to revive it?
Both the breathing white, and the never-ending magenta on the cc3000 patch sounds just like the behavior I saw when my cc3000 nvmem got corrupted. I’m sorry to say I didn’t find a solution to that. Yours may or may not have the same problem, but the symptoms sound similar.
So… how do I go about getting my Spark fixed or replaced?I don’t see anywhere to submit a support ticket, and Spark doesn’t seem to have a phone number…
Hi there @Peter I did get your support ticket and we are working on a solution for you. Just wanted to let you know that we haven’t forgotten about you.
since now I have the same problem. The Core was working fine by now. If I connect it to the power supply it only pulsing white. Flashing the cc3000 patch ends in a endless magenta blinking.
