Particle Core glowing white – did I brick it?
Hi, my Particle Core begins to glow white as soon as I connect it to power. Factory reset did not help, also not flashing the firmware via USB. The issue is described exactly in this unresolved question from @lloydo.
I suspect I bricked it while soldering a VCC wire while it was powered on?
How can I make sure it’s or it’s not? Thank you very much.
Addendum
What happens when I follow steps from Spark Core Common Issues, “Very old Spark core and want to update stuff”:
  • (DFU mode) particle flash --factory tinker
    • “Flash success!”, then blinking yellow
  • (DFU mode) particle flash --usb cc3000 or particle flash --usb cc3000_1_14 (see)
    • “Flash success!”, then blinking magenta, more than 15 minutes
More things I tried
Are you able to place it in DFU mode?
Yes, I can put it in DFU mode.
Can you do:
  • particle flash --factory tinker
  • particle flash --usb cc3000 (it should blink magenta and revert to yellow)
  • particle flash --usb tinker
  • particle flash --factory tinker goes through, LED blinking yellow afterwards
  • particle flash --usb cc3000 blinks magenta indefinitely
  • (particle flash --usb tinker after flashing: breathing white)
    I read somewhere that breathing white signalled faulty communication with the cc3000 chip. So is my cc3000 bricked? Hm…
Sounds like the case
@akrusen, did you redo the wifi configuration ?
I did a particle serial wifi.
$ particle serial wifi
? Should I scan for nearby Wi-Fi networks? Yes
? Select the Wi-Fi network with which you wish to connect your device: WIFINAME
? Should I try to auto-detect the wireless security type? Yes
> Detected WPA2(PSK/AES/AES) security
From here, the Core hangs. I quit this after ten minutes.
(Now I remember that I had been having this kind of issues for half a year. Then, only a wifi configuration reset helped: holding MODE until the LED blinked blue.)
Holding MODE now for 20 seconds or so only freezes the white breathing.
Help with this topic was friendly, but:
With a heavy heart I accept that my beloved Particle Core is gone. Farewell!
