Spark pulses cyan, but not seen in IDE
Used iphone to config & spark pulsing cyan. Can’t see it from IDE. Is there a chance that this spark unit was pre-owned and bound to someone elses account?
Pulsing cyan means the core is connected to the Wifi network but unable to connect to the spark :cloud:.
You might need to share more information of your network setup like channel, mode, security type etc :smiley:
What is the difference between the core and the spark? I thought they were the same? My wifi is unsecured. I have downloaded the CLI tool and when I run it, I get the following messages:
spark setup
Setup your account
You are already logged in as: x@y.com
Logged in! Saving access token: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Finding your core id
Your core id is: core id is YYYYYYYYYYYYYYYYYYYYYYYY
Setup your wifi
SSID: GoNuts
Security 0=unsecured, 1=WEP, 2=WPA, 3=WPA2: 0
Attempting to configure wifi on /dev/cu.usbmodemfd131
I said: w
Serial said: SSID:
I said: GoNuts
Serial said: GoNuts
I said: 0
Serial said: 0
Thanks! Wait about 7 seconds while I save those credentials…
Serial said: Awesome. Now we’ll connect!
If you see a pulsing cyan light, your Spark Core
has connected to the Cloud and is ready to go!
If your LED flashes red or you encounter any other problems,
visit https://www.spark.io/support to debug.
Spark <3 you!
Done! Your core should now restart.
Please wait until your core is breathing cyan and then press ENTER
Claiming your core
Failed to claim core, server said [ ‘Device is not connected’ ]
Can you try restarting your core and see if it reaches breathing cyan?
Yes, it flashes green for about two seconds and goes to pulsing cyan.
Can i recommend setting up a hotspot on your phone and send the Wifi credentials via Spark-cli?
Press the MODE button for 4 seconds till the core blinks blue. Use the command spark setup wifi and you are good to go!
Let us know how it goes :wink:
Interesting, do you think that there may be an issue with my office wi-fi and you want me to use the phone as a hotspot to see if we get other results? I have an iphone, so hotspot is not free, but I do have another router I can use.
It might be and issue since you mentioned office :wink:
Does it have some login portal or authentication? The core will not be able to handle that. :smiley:
You can safely try with your hotspot for few minutes. The data usage is minimal :smiley:
Thanks, let me call my wife, she manages the phone bill like a hawk. :wink:
