I have been donated an older Spark Core v1.
When connecting it to my PC, I get a cyan breathing for 1 second, then solid blue for 1 second… flashing blue light…maybe twice a second.
My PC sees no USB device.
I’ve installed the Spark drivers.
The CLI
But nothing.
I’ve tried to hold down Reset + Mode… then release reset… holding the mode button down…device resets… but just returns to the blue flashing LED…
With Cores it's likely that it suffers from "amnesia"
The Core can be factory reset: press/hold SETUP, tap RESET, keep holding SETUP till you see rapid white blinking.
After that you can try revive it via CLI in DFU Mode (blinking yellow)
I think the device is possibly faulty. I’ve tried the Hold Mode down… tap reset… and continue holding Mode until the flashing white. But, it never goes to flashing white. It goes back to flashing blue… and I’m still holding the mode button.
Sometimes, it seems to go into a rapidly flashing cyan… and sometimes, it goes into flashing green.
My technique:
Device plugged in and flashing blue.
HOld down Mode.
Press Reset.
Continue holding mode…
Device goes off, comes back and… and returns to flashing blue.
Release Mode.
You might be right. I’m not sure if there’s a way I can check. When the device is on and flashing blue - should pressing mode do anything?
When I hold down reset and mode - a small blue light lights up at the top right of the board. Very faint. (Top right if looking at the board with the USB port at the top).
