Not sure what happened but I didn’t change any of the Electronics I had plugged in at all. I merely tried to update the application I had written. I’m not sure if there was some loose connection or something but now my spark core won’t turn on at all.
When powered up the small blue LED flashes once only and then goes out for good until I power cycle again. Is that the end of my core?? I have it powered by an Apple USB plug - which I thought was fine to use…
Any suggestions to fix it?
