Guys,
I trying to use http://build.particle.io/build to upload my code but my devices are not listed on “Devices”.
Flashing => Error: No devices associated with your account, but it’s listed on mobile app.
Claim a device don’t solve this problem.
Thank you.
Moors7
August 20, 2015, 7:23pm
2
Try logging out and in again. It’s fairly easy to log in with incorrect credentials.
I did this and in an anonymous tab too. No success.
Moors7
August 20, 2015, 7:28pm
4
Are your programs listed correctly, or is this the first time your trying to use your devices?
Yes, programs are listed. I have 2 and used without problems until change spark for particle.
Dave
August 20, 2015, 8:38pm
6
Hi @SalomaoJr ,
You have two accounts. One of them ends with “s” instead of “r”.
David
with the same email address?
My devices are listed in the spark mobile app with salomaojr… Can you say me the email of the “s” account?
Dave
August 20, 2015, 9:11pm
8
Sent you a private message
hsm
August 20, 2015, 9:24pm
9
I have the same issue with a Spark core. It started a couple of hours ago.
hsm
August 21, 2015, 8:20am
11
The previously claimed Spark Core no longer shows up under “Particle Devices” in Particle Build. This means that the Web IDE can no longer be used to flash the Spark.
Compiling and flashing with particle-cli works, however.
See also Spark Core gone from Device listing, can't add it back
Weird. I think it’s just having issues being listed in the Web IDE.
Can you check particle list and see if all your existing devices are there?
Ping @suda
hsm
August 21, 2015, 8:56am
13
The device is there when using particle list.
This topic is now closed. New replies are no longer allowed.
As @suda is looking into this in the parallel thread
Please PM him your device ID and continue in the other thread.
