Hello,
Spark Dev stopped showing cores. When ever I click on “select device” It shows “Loading devices…” but the list stays empty.
Any suggestion how to fix this?
Markus
Hello,
Markus
Are you seeing anything in the console debugging window? If not, shoot hello@spark.io and email with your username/email you use for Spark Dev and we’ll look into it
Happened to me recently and it was expired access token or something like it. Choosing “Spark > Logout” from menu and loggin in back again fixed it.
By the way, I somehow missed documentation if there is better way to do that.
@lami: Thanks, that fixed it!
