[SOLVED] Particle Web IDE: Uploading a project — SOLUTION: Customise Particle Workbench
Hey @rei_vilo,
I was able to add support for the redbear duo in Workbench with the following:
cd ~/.particle/toolchains/deviceOS
git clone https://github.com/redbear/firmware redbearduo
cd redbearduo
git submodule update --init --recursive
mkdir .workbench
nano .workbench/manifest.json
Put the following contents in .workbench/manifest.json:
    "version": "1.0.0",
    "toolchains": [
            "firmware": "deviceOS@source",
            "compilers": "gcc-arm@5.3.1",
            "debuggers": "openocd@0.11.2-adhoc6ea4372.0",
            "platforms": [1],
            "scripts": "buildscripts@1.9.2",
            "tools": "buildtools@1.1.1"
    "platforms": [
            "id": 1,
            "name": "duo",
            "generation": 1
In Workbench I set the Custom Device OS Location to ~/.particle/toolchains/deviceOS/redbearduo
Next, I opened created a new Workbench project and I selected the deviceOS@source firmware and the duo device:
After that, I was able to compile the project for the redbear duo.
Sources:
https://support.particle.io/hc/en-us/articles/360039251434/#working-with-a-custom-device-os-build
