The Particle extension Workbench Core has been updated to v1.14.11.
The solution for [SOLVED] Particle Web IDE: Uploading a project — SOLUTION: Customise Particle Workbench - #4 by nrobinson2000 no longer works when I try to target the Core+Photon.
Visual studio Code with the Particle Workbench extension now throws an error when I load the project:
Invalid toolchain manifest!
Error: Invalid toolchain manifest!
at module.exports.validateJSON (/Users/USER/.vscode/extensions/particle.particle-vscode-core-1.14.11/node_modules/@particle/toolchain-manager/src/manifest/loader.js:103:9)
at module.exports.mergeJSON (/Users/USER/.vscode/extensions/particle.particle-vscode-core-1.14.11/node_modules/@particle/toolchain-manager/src/manifest/loader.js:66:3)
at Object.module.exports.mergeOverrideFileSync (/Users/USER/.vscode/extensions/particle.particle-vscode-core-1.14.11/node_modules/@particle/toolchain-manager/src/manifest/loader.js:88:9)
at Function.mergeManifestForDeviceOSSync (/Users/USER/.vscode/extensions/particle.particle-vscode-core-1.14.11/node_modules/@particle/toolchain-manager/src/toolchain.js:83:25)
at loadManifestAndReportErrors (/Users/USER/.vscode/extensions/particle.particle-vscode-core-1.14.11/src/index.js:165:13)
at module.exports.activate (/Users/USER/.vscode/extensions/particle.particle-vscode-core-1.14.11/src/index.js:32:3)
at Function._callActivateOptional (/Applications/Visual Studio Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:88:17454)
at Function._callActivate (/Applications/Visual Studio Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:88:17119)
at /Applications/Visual Studio Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:88:14937
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async _activate (/Applications/Visual Studio Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:83:8180)
at async _waitForDepsThenActivate (/Applications/Visual Studio Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:83:8122)
at async _initialize (/Applications/Visual Studio Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:83:7486)
"keyword": "required",
"dataPath": ".platforms[11]",
"schemaPath": "#/required",
"params": {
"missingProperty": "baseMcu"
"message": "should have required property 'baseMcu'"
I searched the Particle Workbench documentation for baseMcu but found no answer so far.
How to keep building against the Core and
Thank you for your help!
