[ISSUE] Particle Workbench can't download 0.6.3 toolchain
When trying to install the local toolchain for v0.6.3 (photon), I get the error:
could not download deviceOS@0.6.3 from https://github.com/particle-iot/firmware/archive/v0.6.3.tar.gz
Downloading and installing the local toolchain for v0.7.0 (photon) worked fine. I’ve tried reinstalling the Particle Workbench extension. A manual download of that file from my computer works fine.
Audit:
*** WARNING: MAY CONTAIN CONFIDENTIAL INFORMATION - PLEASE SANITIZE BEFORE SHARING ***
To report an issue, visit:
https://community.particle.io/t/information-how-to-report-bugs-and-provide-feedback/44245
    "username": "{REDACTED}",
    "workspace": {
        "name": "gateway-firmware (Workspace)",
        "isWorkspace": true,
        "configFile": "gateway-firmware.code-workspace",
        "root": "/Users/justicereed/Documents/Engineering/Hardware/gateway-firmware",
        "files": [
         {REDACTED}
    "vscode": {
        "appName": "Visual Studio Code",
        "appRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
        "machineId": "4cc4cb9a12ea10c756da5e4376e9dea6d7c38af8833f85573107faa9b6beb4e8",
        "sessionId": "c26063f1-55ba-4244-b64b-57550e8cf60b1547228823444",
        "version": "1.30.2"
    "cli": {
        "binpath": "/Users/justicereed/.vscode/extensions/particle.particle-vscode-core-1.0.0-alpha.6/src/cli/bin/darwin/amd64/particle",
        "ok": true,
        "version": "1.37.0"
    "localCompiler": {
        "dependencies": [
            "deviceOS@0.7.0",
            "gcc-arm@5.3.1",
            "buildtools@1.0.1",
            "buildscripts@1.0.0",
            "deviceOS@0.6.4",
            "gcc-arm@4.9.3"
    "platform": {
        "os": "darwin",
        "type": "Darwin",
        "release": "18.0.0",
        "arch": "x64",
        "path": {
            "key": "PATH",
            "value": "/Users/justicereed/.nvm/versions/node/v8.9.4/bin:/Users/justicereed/Library/Python/3.6/bin:/Users/justicereed/bin:/Library/Frameworks/Python.framework/Versions/3.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Applications/Postgres.app/Contents/Versions/latest/bin"
        "homeDir": "/Users/justicereed",
        "particleDir": "/Users/justicereed/.particle",
        "localCompilerToolchainDir": "/Users/justicereed/.particle/toolchains"
    "env": {
        "TMPDIR": "/var/folders/60/_39c6nf109v28rbbvzcwwxnh0000gn/T/",
        "__CF_USER_TEXT_ENCODING": "0x1F5:0x0:0x0",
        "SHELL": "/bin/bash",
        "HOME": "/Users/justicereed",
        "Apple_PubSub_Socket_Render": "/private/tmp/com.apple.launchd.d5yGv5hPUK/Render",
        "SSH_AUTH_SOCK": "/private/tmp/com.apple.launchd.CEQc881I3b/Listeners",
        "PATH": "/Users/justicereed/.nvm/versions/node/v8.9.4/bin:/Users/justicereed/Library/Python/3.6/bin:/Users/justicereed/bin:/Library/Frameworks/Python.framework/Versions/3.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Applications/Postgres.app/Contents/Versions/latest/bin",
        "LOGNAME": "justicereed",
        "XPC_SERVICE_NAME": "com.microsoft.VSCode.1508",
        "USER": "justicereed",
        "XPC_FLAGS": "0x0",
        "VSCODE_NLS_CONFIG": "{\"locale\":\"en-us\",\"availableLanguages\":{},\"_languagePackSupport\":true}",
        "VSCODE_NODE_CACHED_DATA_DIR": "/Users/justicereed/Library/Application Support/Code/CachedData/61122f88f0bf01e2ac16bdb9e1bc4571755f5bd8",
        "VSCODE_LOGS": "/Users/justicereed/Library/Application Support/Code/logs/20190111T111835",
        "VSCODE_IPC_HOOK": "/Users/justicereed/Library/Application Support/Code/1.30.2-main.sock",
        "VSCODE_PID": "62771",
        "NVM_BIN": "/Users/justicereed/.nvm/versions/node/v8.9.4/bin",
        "NVM_CD_FLAGS": "",
        "NVM_DIR": "/Users/justicereed/.nvm",
        "PWD": "/",
        "SHLVL": "1",
        "_": "/Applications/Visual Studio Code.app/Contents/MacOS/Electron",
        "AMD_ENTRYPOINT": "vs/workbench/node/extensionHostProcess",
        "PIPE_LOGGING": "true",
        "VERBOSE_LOGGING": "true",
        "VSCODE_IPC_HOOK_EXTHOST": "/var/folders/60/_39c6nf109v28rbbvzcwwxnh0000gn/T/vscode-ipc-551a67b8-6ef8-4d6b-abbd-8e4ef30bf2ab.sock",
        "VSCODE_HANDLES_UNCAUGHT_ERRORS": "true",
        "VSCODE_LOG_STACK": "false",
        "VSCODE_LOG_LEVEL": "undefined",
        "VSCODE_PREVENT_FOREIGN_INSPECT": "true",
        "CRASH_REPORTER_START_OPTIONS": "{\"companyName\":\"Microsoft\",\"productName\":\"VSCode\",\"submitURL\":\"https://rink.hockeyapp.net/api/2/apps/21a48a66799e47fea4f52c0ff81e803d/crashes/upload\",\"extra\":{\"vscode_version\":\"1.30.2\",\"vscode_commit\":\"61122f88f0bf01e2ac16bdb9e1bc4571755f5bd8\",\"vscode_sessionId\":\"c26063f1-55ba-4244-b64b-57550e8cf60b1547228823444\",\"processName\":\"extensionHost\"},\"crashesDirectory\":\"/var/folders/60/_39c6nf109v28rbbvzcwwxnh0000gn/T\"}",
        "ELECTRON_RUN_AS_NODE": "1",
        "APPLICATION_INSIGHTS_NO_DIAGNOSTIC_CHANNEL": "true"
    "versions": {
        "http_parser": "2.7.0",
        "node": "8.9.3",
        "v8": "6.1.534.41",
        "uv": "1.15.0",
        "zlib": "1.2.11",
        "ares": "1.10.1-DEV",
        "modules": "57",
        "nghttp2": "1.25.0",
        "openssl": "1.0.2n"
    "extensions": [
            "id": "ms-vscode.node-debug",
            "version": "1.30.4"
            "id": "ms-vscode.node-debug2",
            "version": "1.30.3"
            "id": "ms-vscode.references-view",
            "version": "0.0.18"
            "id": "marus25.cortex-debug",
            "version": "0.1.21"
            "id": "ms-vscode.cpptools",
            "version": "0.20.1"
            "id": "particle.particle-vscode-core",
            "version": "1.0.0-alpha.6"
            "id": "particle.particle-vscode-snippets",
            "id": "particle.particle-vscode-theme",
Thanks for reporting. This was a consequence of the Device OS 1.0.0 release and changing path of the Git repo. We’re working on a new Alpha drop which fixes this and should be available soon.
