Actually, if you have CLI included in your path, you can place the files wherever you like, you only need to either be in that respective directory (cd \to\that\folder) before you execute that command, or you’d need to provide the full path and not only the file name
I tried to navigate to the directory in the CLI, but I didn't know I need to put the "cd" before the path
Thank you for the tip!
This week I figured out how to use the CLI, and I found the Particle DEV software. For some reason, I thought people were using the CLI to do the offline coding The Particle DEV is a nice piece of software.
