Hi Guys
I’m trying to update my Electron via the particle-cli app, however when I run the command “particle cloud login” or even “particle login” my command line just hangs.
I have node and particle-cli installed and updated, and I am running on a Mac OSX
If I run “particle” I get the following output:
Welcome to the Particle Command line utility!
Version 1.11.0
Usage: particle <command_name>
Common Commands:
setup, list, call, get, device, identify, flash, subscribe
compile, monitor, login, logout, help
Less Common Commands:
token, binary, cloud, config, function, keys, serial, udp
update, variable, webhook, wireless
For more information Run: particle help <command_name>
Any ideas?
Thanks in advance
cloud?
