Dear community,
This is first time i’m using Particle CLI. After finishing setup using ParticleCLISetup.exe, i’m running command line “particle setup”. After choose login, it’s hang.
I’m using windows 10
Need help, I cannot claim my devices
Dear community,
Can you try particle login instead of particle setup?
Does your machine have internet connection without too restrictive firewall settings? (maybe @rickkas7 can fill in which ports CLI needs to be open - this would be useful info in the CLI install docs)
Yes, I’d first try particle login. The Particle CLI needs access to api.particle.io (TCP 443 outbound). It needs access to binaries.particle.io (TCP 443 outbound) to update itself (particle update-cli). Make sure those are not blocked by a firewall.
But did you try?:
particle login
That is your private firewall, are you behind a corpoarate firewall too?
Does your ISP block anything?
Is this a standard Win10 installation or a VM?
Could it be that you are using “exotic” characters in your password?
Was this problem resolved? I’m actually having the same issue.
When I enter my username/password, or in fact ANY characters, node just hangs.
Cheers
