[SOLVED] Particle CLI Installation Failure
hey y’all,
Having a whale of a time with the CLI on WIndows x64 Version 10 Enterprise 10.0.17134.
Particle-cli v2 worked w/o issues, apparently got autoupdated(?) and it started complaining about missing modules.
So, tried upgrading/re-installing and it fails with npm errors.
I am behind a corporate proxy, which was never an issue before.
IT says nodejs.org and github.com are whitelisted.
Any recommendations?
Same results whether the windows installer, Workbench or npm install.
See below log.
λ npm install --loglevel verbose -g git+ssh://git@github.com:particle-iot/particle-cli
npm verb cli [
npm verb cli   'C:\\Program Files (x86)\\nodejs\\node.exe',
npm verb cli   'C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
npm verb cli   'prefix',
npm verb cli   '-g'
npm verb cli ]
npm info using npm@8.1.2
npm info using node@v16.13.2
npm timing npm:load:whichnode Completed in 0ms
npm timing config:load:defaults Completed in 2ms
npm timing config:load:file:C:\Program Files (x86)\nodejs\node_modules\npm\npmrc Completed in 2ms
npm timing config:load:builtin Completed in 3ms
npm timing config:load:cli Completed in 2ms
npm timing config:load:env Completed in 1ms
npm timing config:load:file:C:\Users\collig\git\prodmon\.npmrc Completed in 0ms
npm timing config:load:project Completed in 2ms
npm timing config:load:file:C:\Users\collig\.npmrc Completed in 1ms
npm timing config:load:user Completed in 1ms
npm timing config:load:file:C:\Users\collig\AppData\Roaming\npm\etc\npmrc Completed in 0ms
npm timing config:load:global Completed in 0ms
npm timing config:load:validate Completed in 1ms
npm timing config:load:credentials Completed in 1ms
npm timing config:load:setEnvs Completed in 1ms
npm timing config:load Completed in 14ms
npm timing npm:load:configload Completed in 14ms
npm timing npm:load:setTitle Completed in 0ms
npm timing npm:load:setupLog Completed in 1ms
npm timing config:load:flatten Completed in 3ms
npm timing npm:load:cleanupLog Completed in 2ms
npm timing npm:load:configScope Completed in 0ms
npm timing npm:load:projectScope Completed in 0ms
npm timing npm:load Completed in 53ms
npm timing command:prefix Completed in 1ms
npm verb exit 0
npm timing npm Completed in 419ms
npm info ok
npm verb cli [
npm verb cli   'install',
npm verb cli   '--loglevel',
npm verb cli   'verbose',
npm verb cli   '-g',
npm verb cli   'git+ssh://git@github.com:particle-iot/particle-cli'
npm verb cli ]
npm timing config:load:builtin Completed in 2ms
npm timing config:load:env Completed in 2ms
npm timing config:load:flatten Completed in 2ms
npm timing npm:load:cleanupLog Completed in 3ms
npm timing npm:load:projectScope Completed in 1ms
npm timing npm:load Completed in 63ms
npm timing arborist:ctor Completed in 1ms
npm timing idealTree:init Completed in 6ms
npm timing idealTree:userRequests Completed in 267327ms
npm http fetch GET 404 https://registry.nodejs.org/cli-spinner 3089ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-library-manager 3112ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/safe-buffer 3139ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/softap-setup 3178ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/binary-version-reader 3201ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/cli-table 3204ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/node-wifiscanner2 3206ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-api-js 3211ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/lodash 3220ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-commands 3236ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/moment 3245ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/inquirer 3256ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/core-js 3265ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/latest-version 3271ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/glob 3279ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/fs-extra 3284ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/handlebars 3292ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/temp 3289ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/semver 3305ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/chalk 3321ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/verror 3317ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/xtend 3321ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/yargs 3331ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/wiring-preprocessor 3339ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/yeoman-environment 3344ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/yeoman-generator 3350ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-usb 3356ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/serialport 3363ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/cli-spinner 294ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-library-manager 286ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/safe-buffer 263ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/softap-setup 231ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/binary-version-reader 227ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/cli-table 227ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/node-wifiscanner2 229ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-api-js 229ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/lodash 227ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-commands 216ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/moment 218ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/inquirer 216ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/core-js 213ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/latest-version 212ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/glob 212ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/fs-extra 221ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/handlebars 220ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/temp 218ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/semver 210ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/chalk 205ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/verror 209ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/xtend 206ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/yargs 202ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/wiring-preprocessor 202ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/yeoman-environment 201ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/yeoman-generator 207ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/particle-usb 204ms (cache skip)
npm http fetch GET 404 https://registry.nodejs.org/serialport 200ms (cache skip)
npm timing idealTree:#root Completed in 520100ms
npm timing idealTree:node_modules/particle-cli Completed in 32ms
npm timing idealTree:node_modules/particle-cli/node_modules/@particle/device-constants Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/binary-version-reader Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/chalk Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/cli-spinner Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/cli-table Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/core-js Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/fs-extra Completed in 1ms
npm timing idealTree:node_modules/particle-cli/node_modules/glob Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/handlebars Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/inquirer Completed in 1ms
npm timing idealTree:node_modules/particle-cli/node_modules/latest-version Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/lodash Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/moment Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/node-wifiscanner2 Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/particle-api-js Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/particle-commands Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/particle-library-manager Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/particle-usb Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/request Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/safe-buffer Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/semver Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/serialport Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/softap-setup Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/temp Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/verror Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/wiring-preprocessor Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/xtend Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/yargs Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/yeoman-environment Completed in 0ms
npm timing idealTree:node_modules/particle-cli/node_modules/yeoman-generator Completed in 0ms
npm timing idealTree:buildDeps Completed in 520167ms
npm timing idealTree:fixDepFlags Completed in 1ms
npm timing idealTree Completed in 787510ms
npm timing command:install Completed in 787524ms
npm verb type system
npm verb stack FetchError: request to https://registry.nodejs.org/@particle%2fdevice-constants failed, reason: read ECONNRESET
npm verb stack     at ClientRequest.<anonymous> (C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\minipass-fetch\lib\index.js:110:14)
npm verb stack     at ClientRequest.emit (node:events:390:28)
npm verb stack     at TLSSocket.socketErrorListener (node:_http_client:447:9)
npm verb stack     at TLSSocket.emit (node:events:402:35)
npm verb stack     at emitErrorNT (node:internal/streams/destroy:157:8)
npm verb stack     at emitErrorCloseNT (node:internal/streams/destroy:122:3)
npm verb stack     at processTicksAndRejections (node:internal/process/task_queues:83:21)
npm verb cwd C:\Users\collig\git\prodmon
npm verb Windows_NT 10.0.17134
npm verb argv "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "--loglevel" "verbose" "-g" "git+ssh://git@github.com:particle-iot/particle-cli"
npm verb node v16.13.2
npm verb npm  v8.1.2
npm ERR! code ECONNRESET
npm ERR! syscall read
npm ERR! errno ECONNRESET
npm ERR! network request to https://registry.nodejs.org/@particle%2fdevice-constants failed, reason: read ECONNRESET
npm ERR! network This is a problem related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
npm ERR! network
npm ERR! network If you are behind a proxy, please make sure that the
npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
npm verb exit 1
npm timing npm Completed in 788151ms
npm verb unfinished npm timer reify 1643838905938
npm verb unfinished npm timer reify:loadTrees 1643838905947
npm verb code 1
npm ERR! A complete log of this run can be found in:
npm ERR!     C:\Users\collig\AppData\Local\npm-cache\_logs\2022-02-02T22_08_13_487Z-debug.log
these troubleshooting steps might be helpful:
I saw that @m_m and went through the suggested steps.
As noted, installation fails in the “standard”, “advanced” and via Workbench.
did you try resetting the installation? if you didn’t spot them, those instructions are here: https://support.particle.io/hc/en-us/articles/1260801311330-Troubleshooting-the-Particle-CLI#:~:text=From%20there%2C%20take%20the%20following%20steps%20to%20reset%20your%20CLI%20installation
I sure did try them. Both on the cli and workbench. Nothing works.
It looks like my corporate proxy/firewall misbehaves w/ TLS used by github/nodejs.
I have to use ssh on github.
IT support is trying, but their whitelisting isn’t fixing the problem.
I am switching gears to go w/o the cli or workbench (since it seems to depend on the cli, unfortunately).
Having some issues getting going that way too.
Put that on separate thread.
Problem solved.
It was a corporate IT proxy/firewall issue, as suggested by the error.
Just for completeness, Visual Code workbench will work w/o the cli.
I just commented out the code below in ~/.particle/toolchains/buildscripts/1.10.0/Makefile:
preprocess: $(value PREPROCESSED_FILES)
	$(call print_stage, PREPROCESSING BY PARTICLE_CLI DISABLED)
#$(value PREPROCESSED_FILES): %.cpp: %.ino
#	@"$(value PARTICLE_CLI_PATH)" preprocess $< --no-update-check --quiet
dfu:
	$(call print_stage,PUT DEVICE INTO DFU MODE MANUALLY!)
	@sleep 20
#	$(call print_stage,PUTTING DEVICE INTO DFU MODE)
#	-@"$(value PARTICLE_CLI_PATH)" usb dfu $(value PARTICLE_DEVICE_ID) --no-update-check --quiet
#	@sleep 2
