Hello y’all,
I have a photon that I cannot get set up correctly. I have used this for various projects but really havne’t messed with it or coding in quite some time. I have downloaded the most recent CLI and dfu-util. I have been able to run particle update
and I get this.
> Your device is ready for a system update.
> This process should take about 30 seconds. Here it goes!
! System firmware update successfully completed!
> Your device should now restart automatically.
I can then enter particle setup
with no problems. It finds the photon, I am logged in and continue with the WiFi setup and this is what I get.
> Setup is easy! Let's get started...
> It appears as though you are already logged in as bry0603
? Would you like to use this account? Yes
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
> I have detected a Photon connected via USB.
? Would you like to continue with this one? Yes
! The device supports setup via serial.
setting up device 1fxxxxxxx.........33
> Obtained magical secure claim code.
Claim code set. Now setting up Wi-Fi
? Should I scan for nearby Wi-Fi networks? Yes
? Select the Wi-Fi network with which you wish to connect your device: xxWiFixx
? Should I try to auto-detect the wireless security type? Yes
> Detected WPA2(PSK/AES/AES) security
? Wi-Fi Password xxCorrect Passxx
Done! Your device should now restart.
! It doesn't look like your Photon has made it to the cloud yet.
? What would you like to do? (Use arrow keys)
❯ Check again to see if the Photon has connected
Reconfigure the Wi-Fi settings of the Photon
After which my photon is just breathing green. I’m stuck. I cannot access it at all via the app, IDE, etc. Any help would be greatly appreciated.
