[Solved] - ERROR 500 when trying to compile
Anyone getting error 500 while trying to verify or compile right now?
Select the Devices icon (the circle with the lines, the target icon), then the Electron or Photon you want build for, click the “>” icon, and verify that the build with firmware popup menu has a valid value.
The setting sometimes get set to something odd, which causes the Error 500. If you have not upgraded the system firmware, and this is an Electron it should be 0.4.8. If a Photon, 0.4.9.
I had to update my firmware to .5.2 and then all was well. Thanks for pointing me in the right direction.
