If I use the bin downloaded from the Electron setup everything is fine and it connects via Google Fi. If I use this code below I get a pulsing magenta code. Any idea? thanks
Roge
#include "Particle.h"
#include "cellular_hal.h"
STARTUP(cellular_credentials_set("h2g2", "", "", NULL));
/* Function prototypes -------------------------------------------------------*/
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
int tinkerAnalogRead(String pin);
int tinkerAnalogWrite(String command);
Particle.keepAlive(240);
//Setup the Tinker application here
//Register all the Tinker functions
Particle.function("digitalread", tinkerDigitalRead);
Particle.function("digitalwrite", tinkerDigitalWrite);
Particle.function("analogread", tinkerAnalogRead);
Particle.function("analogwrite", tinkerAnalogWrite);
/* This function loops forever --------------------------------------------*/
return -2;
return -3;
return -2;
return -2;
