Size of JST battery connector for particle electron
I’d like to have a spare battery with the same JST connector for the Electron. Anyone know what the size is?
The connector type is JST-PH.
https://www.adafruit.com/?q=JST-PH
cheers,
ParticleD
How many MM, I am looking to get a lower power battery (size constraint) . but the batteries while coming in “JST” are multiple mm sizes from about 1 to 2.5
the ones i get are 2 pin JST-PH which come in 2mm-pitch, if that is what you are asking about.
http://www.jst-mfg.com/product/pdf/eng/ePH.pdf
however it has been necessary in the past to buy a battery with a different connector and then swap it out with a JST-PH. not all batteries come with a connector or the right connector.
Thanks!, I’ll try one and let you know.
