Muon 3-pin JST battery connector
Does this connector have a 1mm or 2mm spacing?
Where can I find the layout of the pins for finding compatible batteries?
It uses the same connector as the M.2 SoM breakout board, a 3-pin JST-PH (2mm). It's basically the same connector as the 2-pin batteries, but with one more pin.
The arrangement of the pins is here and the pack thermistor is a 10K NTC thermistor connected to GND.
The Muon versions that include a battery have a single 3100 mAh 18650 cylindrical battery.
Good to know, as I didn't see the battery listed in the Muon contents. Thanks.
Sorry about that - I just realized that not all versions of the Muon include a battery. I updated the text above.
