Hi, I am using Long Range IoT Wireless Temperature Humidity Sensor for measuring machine vibration and temperature and able to send data to console.particle. Can you suggest me how to send the vibration and temp data to google sheet for predictive analysis?
Have you read this introductory post - especially Step 2?
(This should be pinned for every new user)
https://community.particle.io/t/welcome-using-particle-forums-and-forum-etiquette
You have a search term “google sheet” which will render many results to investigate first
Hi Collin,
I wrote about one way of doing it here:
and this is another topic with few other options I think:
Good luck!
Gustavo.
