I use B524MEA Europe with Bluetooth Antenna ANT-FLXV2. I found RoHS and CE certificate of B524 but not the antenna ANT-FLXV2. Is it this antenna not certified as standalone unit? If yes, is this antenna certified with B524 or with another device?
Where do I get the RoHS cert. for this antenna? or RoHS statement?
Antennas aren't separately CE certified; the certification applies to the combination of the transmitter (B524) and the antenna.
The ANT-FLXV2 is RoHS certified by the antenna manufacturer, but I have not located the document. Usually it's included in the antenna datasheet, but not in this case.
The ANT-FLXV2 is the required antenna for Wi-Fi with the Argon kit, which does have RoHS certification, so the certification exists, I just don't have the document at the moment.
