I have recently found the need to use the desktop IDE for some Electron development and decided to try this IDE for the RedBear Duo. So far I’ve been using the web IDE for Duo without any issues.
I have discovered that I can compile for any platform except the Duo. I’ve even tried Tinker and get the same compiler message, “Compiler timed out or encountered an error”.
At this point I’m trying Tinker, on Duo 0.3.1, IDE version 1.18.0 x64 on windows 7. Tried the same at home on windows 10 with the same result.
Is Duo development on the desktop IDE not supported or is this an issue already being worked on?
Thanks in advance
