RedBear Duo Error 500 Web IDE
Has support for the RedBear Duo recently been dropped? I have been using the Web IDE for many years now and I am now getting an Error 500 when I try to compile my code. Firmware on the Duo is 0.4.9 and the Web IDE detects my RedBear Duo. Just won't compile and flash.
I used the Web IDE a few months back without any problem.
Can support be added back into the Web IDE?
What are my options if it has been drop. The RedBear Duo is critical to testing my apps developed for iOS and Android.
Unfortunately it is not possible to program the RedBear Duo with the WebIDE or the Particle cloud compilers. It is well beyond the end of support date for that product.
Hey, what is it that they are doing for your mobile apps? I wonder if the same can be implemented with a Photon 2.
Best,
It was working a few months ago. So it is not like they dropped support years ago. They did something recently to remove the files I need to compile so I now get the 500 error.
What's the problem to keep supporting it?
I don't need technical support just don't disable compiling and installing.
I just need to compile my programs like I have been doing for years now and will for the foreseeable future.
Never mind.
Switched over to running offline on my PC with Arduino.
Was not a good idea to use Particle as a critical part of my development process for a long term projects spanning 10 years.
