The web IDE has started throwing errors when attempting to compile or flash code. I am unable to push OTA updates to devices as a result.
Specifically, I’m seeing the following response from the https://api.particle.io/v1/apps/{app ID}/binaries endpoint through the chrome developer console: {"ok":false,"code":200,"output":"Compiler timed out or encountered an error","errors":[]}. This is being called from Particle Web IDE.
This is occurring across all projects. Clearing the Particle cache and logging out and then back in have had no effect.
