The server has failed ... Compiling error?!
Hi everyone,
I’m trying to compile my code and every time I get the response
"The server has failed to process the request on time. Please try again."
Any ideas what I can do or what I have done wrong?
Cheers,
Leopold
I guess you are talking about Particle Build (aka Web IDE).
No issue on my side, and http://status.particle.io/ also reports no outage.
Can you try to restart your browser and clear the browser cache or use Incoginto Mode?
Hi ScruffR,
yes, I’m using Particle Build. Will try so.
It worked, thank you very much!
