Problems with de web IDE
Hello, I get the error:
The server has failed to process the request on time. Please try again.
And I cant compile any code or flash it. Can I get any help? Thank you
Hey Poncho,
Thanks for being patient with the Web IDE, I believe that @stefanmoraru can help you get connected so that you are able to compile and flash code.
Kyle
Your platform (Photon, Electron, Bluz, …) and the targeted system version number should always be stated in such a case.
Also providing a screenshot (including the status line of the Web IDE window) often also gives some clues.
