Hello
I am Trying to unclaim a particle Argon
Wich is used in laboratory by m’y student in the past.
When I try to restore device IT WORK
At the END off restore this message appear
Claiming device failed
How can i Do to unclaim the device
Thank you for help
You will need to force claim the device.
- Connect the Argon by USB to a computer
- Go to this special setup page in Chrome, Edge, or Opera.
- Select the Argon.
- Click “Advanced Setup Options”
- Click “Force claim a Wi-Fi device using a claim code”
- Continue through the setup steps.
Hello
THANKS YOU FOR YOUR response
I Found the problème
The argon is associated with a groupe
I retreive the Argon from the group
THANKS
