Photon: Problem can't scan Wifi
Hey everyone,
I have problem with scanning WiFi after the password changed.
When I use particle serial wifi I can’t find Name of the router.
Also when I use different Wifi then I reset the credential on the photon again the WiFi will disappear.
could anybody help me on that.
Your problem description is not very clear to me.
Can you elaboarte a bit more and maybe even show your code?
Hi @Lahmdi - we’ve seen your Support Request and one of our TSE’s will get to you shortly. I’ll post results here if the answer is noteworthy!
Hi @ScruffR , @marekparticle ,
Thanks for your effort.
the problem solved after I reinstall the CLI and photon drive.
now it is connected to the Wifi.
Thanks again for your help.
Best regards,
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
