I just got a new photon p1 running on 0.5.3 and I’m having issues staying connected to the wifi at work. I can get it to connect every once in a while but its very unstable and often wont reconnect. The wifi at work is WPA2 AES secured and there are a ton of devices connected to it. I tried the photon on my home network at it worked like a charm. It took only a few seconds to connect and never lost connection.
I only need to be connected to the wifi to pull data once per hour so I don’t need a constant connection but my code won’t run while trying to connect. Has anyone had any connection issues with a p1 on a busy network before?
