Photon dropping WiFI Daily, requires reboot
I have a new photon that is connected to my home internet connection via wifi. When I leave it powered on, every morning it is flashing blue light showing it can’t connect to Wifi. If I power cycle it, it connects immediately and all is good.
Is anyone else having problems keeping their Photon on wifi? I’ll do some more research on my end to see if there is anything with my network. I have a Core on the same network not having a problem.
I think this is probably also part of the discussion over at
Long Term Photon Connection Stability
that said maybe you could join in the search. As I wrote over there there are signs that it has todo with losing Internet with gaps in Internet connectivity with my working hypothesis that cloud pings timing out somehow lead to too aggressive resets sometimes also resulting in permanently failing reconnects. My current test with a Spark.disconnect() in setup() has
been running for 1 day and 7 hours so it is still too early to call.
There have been significant WiFi improvements in the latest release. Please try that! https://github.com/spark/firmware/releases/
This has been fixed with the recent updates.
