Photon not reconnect to WIFI after WIFI is down
Hi, I have problem with my Photon.
I have a daily WIFI restarts on the router, and Photon recconect to the WIFI fine.
But sometimes, when internet is down also with WIFI, Particle show dark blue status led and nothing changed during photon restart. I see in docs, that photon is not connected to WIFI, but why?
Is there any solution, to keep trying to connect? Or where could by a problem?
WIFI signal is strange!
Thank for help.
Hi @MrFiliper ,
How are you? Could you provide more details on your issue? Do you have any extra peripherals attached? What Device OS are you on? Can you test on Device OS 3.0.1?
Would you provide a sample / stripped down firmware which can reproduce this?
Thank you!
