here is my Audit Log
*** WARNING: MAY CONTAIN CONFIDENTIAL INFORMATION - PLEASE SANITIZE BEFORE SHARING ***
To report an issue, visit:
Hello Particle Workbench users
We greatly value your feedback - to help us better diagnose and fix your issue as quickly as possible, here’s what you can do:
Search in the community for similar reports - often times your question will have already been asked and answered
Create a new topic / thread and include the “[ISSUE]” prefix - this will help us quickly differentiate bug reports from general questions / discussion
Verify you are using the latest versions of VSCode & Particle W…
"username": "lawson.fisher@m8systems.com",
"workspace": {
"name": "PCB_Test",
"isWorkspace": false,
"folders": [
"location": "c:\\Users\\lawson\\Documents\\work\\M8Systems\\Engineering\\Firmware\\PCB_Test",
"hasValidPath": true,
"settings": {
"firmwareName": "deviceOS",
"firmwareVersion": "2.0.0",
"targetDevice": "Tracker1",
"targetPlatform": "tracker",
"compileButtonAction": "localAppDeviceOS",
"flashButtonAction": "localAppDeviceOS",
"disableWelcomeScreen": false,
"disableDeviceOSOutdatedCheck": true,
"disableLocalCompilerDirtyCheck": false,
"enableVerboseLocalCompilerLogging": true,
"compileDefines": [],
"customDeviceOSLocation": "",
"maxAllowedToolchains": 4
"files": [
".vscode",
".vscode\\arduino.json",
".vscode\\c_cpp_properties.json",
".vscode\\launch.json",
".vscode\\settings.json",
"lib",
"lib\\I2cMaster",
"lib\\MCP23008-I2C",
"lib\\RTClibrary",
"project.properties",
"README.md",
"src",
"src\\PCB_Test.ino"
"cli": {
"binpath": "c:\\Users\\lawson\\.vscode\\extensions\\particle.particle-vscode-core-1.13.0\\src\\cli\\bin\\windows\\amd64\\particle.exe",
"ok": true,
"version": "2.9.1",
"installed": 1605889427083
"localCompiler": {
"ok": false,
"dependencies": [
"id": "deviceOS@2.0.0",
"ok": true
"id": "gcc-arm@9.2.1",
"ok": true
"id": "buildtools@1.1.1",
"ok": false
"id": "buildscripts@1.9.2",
"ok": true
"id": "openocd@0.11.2-adhoc6ea4372.0",
"ok": true
"id": "deviceOS@2.0.0-rc.4",
"ok": true
"id": "deviceOS@1.5.2",
"ok": true
"id": "gcc-arm@5.3.1",
"ok": true
"platform": {
"os": "windows",
"type": "Windows_NT",
"release": "10.0.18363",
"arch": "x64",
"path": {
"key": "Path",
"value": "C:\\Program Files\\AdoptOpenJDK\\jdk-11.0.8.10-openj9\\bin;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\ActiveTcl\\bin;C:\\Python3.7\\Scripts\\;C:\\Python3.7\\;C:\\ProgramData\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\ATI Technologies\\ATI.ACE\\Core-Static;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\QuickTime\\QTSystem\\;C:\\Program Files\\PuTTY\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Users\\lawson\\.particle\\toolchains\\buildtools\\1.1.1\\bin;C:\\Users\\lawson\\AppData\\Local\\Programs\\Python\\Python38-32\\Scripts\\;C:\\Users\\lawson\\AppData\\Local\\Programs\\Python\\Python38-32\\;C:\\Users\\lawson\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\lawson\\AppData\\Local\\Programs\\Fiddler;C:\\Users\\lawson\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\lawson\\AppData\\Local\\particle\\bin;C:\\OpenSSL-Win32\\bin;C:\\Program Files (x86)\\GitHub CLI\\;C:\\Users\\lawson\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\lawson\\.dotnet\\tools;C:\\Users\\lawson\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\lawson\\.particle\\toolchains\\buildtools\\1.1.1\\bin;"
"homeDir": "C:\\Users\\lawson",
"particleDir": "C:\\Users\\lawson\\.particle",
"localCompilerToolchainDir": "C:\\Users\\lawson\\.particle\\toolchains"
"env": {
"ACTEL_FOR_ALTIUM_OVERRIDE": " ",
"ALLUSERSPROFILE": "C:\\ProgramData",
"ALTERA_FOR_ALTIUM_OVERRIDE": " ",
"AMD_ENTRYPOINT": "vs/workbench/services/extensions/node/extensionHostProcess",
"APPDATA": "C:\\Users\\lawson\\AppData\\Roaming",
"APPLICATION_INSIGHTS_NO_DIAGNOSTIC_CHANNEL": "true",
"asl.log": "Destination=file",
"CARBON_MEM_DISABLE": "1",
"CHROME_CRASHPAD_PIPE_NAME": "\\\\.\\pipe\\crashpad_18984_SAQASYSMXSVRLCNP",
"CommonProgramFiles": "C:\\Program Files\\Common Files",
"CommonProgramFiles(x86)": "C:\\Program Files (x86)\\Common Files",
"CommonProgramW6432": "C:\\Program Files\\Common Files",
"COMPUTERNAME": "LAWSON-PC",
"ComSpec": "C:\\WINDOWS\\system32\\cmd.exe",
"DriverData": "C:\\Windows\\System32\\Drivers\\DriverData",
"ELECTRON_RUN_AS_NODE": "1",
"FPS_BROWSER_APP_PROFILE_STRING": "Internet Explorer",
"FPS_BROWSER_USER_PROFILE_STRING": "Default",
"HOMEDRIVE": "C:",
"HOMEPATH": "\\Users\\lawson",
"LOCALAPPDATA": "C:\\Users\\lawson\\AppData\\Local",
"LOGONSERVER": "\\\\LAWSON-PC",
"NUMBER_OF_PROCESSORS": "8",
"OneDrive": "C:\\Users\\lawson\\OneDrive",
"OPENSSL_CONF": "C:\\OpenSSL-Win32\\bin\\openssl.cfg",
"ORIGINAL_XDG_CURRENT_DESKTOP": "undefined",
"OS": "Windows_NT",
"Path": "C:\\Program Files\\AdoptOpenJDK\\jdk-11.0.8.10-openj9\\bin;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\ActiveTcl\\bin;C:\\Python3.7\\Scripts\\;C:\\Python3.7\\;C:\\ProgramData\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\ATI Technologies\\ATI.ACE\\Core-Static;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\QuickTime\\QTSystem\\;C:\\Program Files\\PuTTY\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Users\\lawson\\.particle\\toolchains\\buildtools\\1.1.1\\bin;C:\\Users\\lawson\\AppData\\Local\\Programs\\Python\\Python38-32\\Scripts\\;C:\\Users\\lawson\\AppData\\Local\\Programs\\Python\\Python38-32\\;C:\\Users\\lawson\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\lawson\\AppData\\Local\\Programs\\Fiddler;C:\\Users\\lawson\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\lawson\\AppData\\Local\\particle\\bin;C:\\OpenSSL-Win32\\bin;C:\\Program Files (x86)\\GitHub CLI\\;C:\\Users\\lawson\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\lawson\\.dotnet\\tools;C:\\Users\\lawson\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\lawson\\.particle\\toolchains\\buildtools\\1.1.1\\bin;",
"PATHEXT": ".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC",
"PIPE_LOGGING": "true",
"PROCESSOR_ARCHITECTURE": "AMD64",
"PROCESSOR_IDENTIFIER": "Intel64 Family 6 Model 60 Stepping 3, GenuineIntel",
"PROCESSOR_LEVEL": "6",
"PROCESSOR_REVISION": "3c03",
"ProgramData": "C:\\ProgramData",
"ProgramFiles": "C:\\Program Files",
"ProgramFiles(x86)": "C:\\Program Files (x86)",
"ProgramW6432": "C:\\Program Files",
"PSModulePath": "C:\\WINDOWS\\system32\\WindowsPowerShell\\v1.0\\Modules\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\PowerShell\\Modules\\",
"PUBLIC": "C:\\Users\\Public",
"PYTHONPATH": "C:/SimpleCV1.3/files/opencv/build/python/2.7/;C:/OpenCV2.3/opencv/build/python/2.7/;C:/SimpleCV1.3/files/opencv/build/python/2.7/;C:/OpenCV2.3/opencv/build/python/2.7/;C:/SimpleCV1.3/files/opencv/build/python/2.7/;C:/OpenCV2.3/opencv/build/python/2.7/;",
"SESSIONNAME": "Console",
"SW_SIM_HYDRA": "C:\\Program Files\\Common Files\\SolidWorks Shared\\Simulation Worker Agent\\",
"SW_SIM_MPIT": "INTELMPI",
"SW_SIM_TEMP": "C:\\ProgramData\\SOLIDWORKS\\SW_net_sim_temp\\",
"SystemDrive": "C:",
"SystemRoot": "C:\\WINDOWS",
"TEMP": "C:\\Users\\lawson\\AppData\\Local\\Temp",
"TMP": "C:\\Users\\lawson\\AppData\\Local\\Temp",
"USERDOMAIN": "LAWSON-PC",
"USERDOMAIN_ROAMINGPROFILE": "LAWSON-PC",
"USERNAME": "lawson",
"USERPROFILE": "C:\\Users\\lawson",
"VERBOSE_LOGGING": "true",
"VSCODE_CWD": "C:\\Users\\lawson\\AppData\\Local\\Programs\\Microsoft VS Code",
"VSCODE_HANDLES_UNCAUGHT_ERRORS": "true",
"VSCODE_IPC_HOOK": "\\\\.\\pipe\\48df312c43e75c9b5eff6be9d6694ad6-1.52.0-main-sock",
"VSCODE_IPC_HOOK_EXTHOST": "\\\\.\\pipe\\vscode-ipc-76a8114b-49fd-4d7d-a4c4-250ec180c92b-sock",
"VSCODE_LOG_STACK": "false",
"VSCODE_NLS_CONFIG": "{\"locale\":\"en-us\",\"availableLanguages\":{},\"_languagePackSupport\":true}",
"VSCODE_NODE_CACHED_DATA_DIR": "C:\\Users\\lawson\\AppData\\Roaming\\Code\\CachedData\\940b5f4bb5fa47866a54529ed759d95d09ee80be",
"VSCODE_PID": "18984",
"windir": "C:\\WINDOWS"
"versions": {
"node": "12.14.1",
"v8": "8.3.110.13-electron.0",
"uv": "1.33.1",
"zlib": "1.2.11",
"brotli": "1.0.7",
"ares": "1.15.0",
"modules": "80",
"nghttp2": "1.40.0",
"napi": "5",
"llhttp": "2.0.1",
"http_parser": "2.8.0",
"openssl": "1.1.0",
"cldr": "36.0",
"icu": "65.1",
"tz": "2020a",
"unicode": "12.1",
"electron": "9.3.5"
"vscode": {
"appName": "Visual Studio Code",
"appRoot": "c:\\Users\\lawson\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
"machineId": "7fa55db6fd88c5dc4109d02b471f2c0c62ab9721a952f9ae89aefaf304236f29",
"sessionId": "1653353a-b65d-4fed-802f-51339a2292201607962017297",
"version": "1.52.0"
"extensions": [
"id": "ms-vscode.js-debug",
"version": "1.52.2"
"id": "ms-vscode.js-debug-companion",
"version": "1.0.8"
"id": "ms-vscode.node-debug",
"version": "1.44.15"
"id": "ms-vscode.node-debug2",
"version": "1.42.5"
"id": "ms-vscode.references-view",
"version": "0.0.74"
"id": "ms-vscode.vscode-js-profile-table",
"version": "0.0.11"
"id": "austin.code-gnu-global",
"version": "0.2.2"
"id": "GitHub.vscode-pull-request-github",
"version": "0.22.0"
"id": "marus25.cortex-debug",
"version": "0.3.7"
"id": "ms-vscode.cpptools",
"version": "1.1.3"
"id": "particle.particle-vscode-core",
"version": "1.13.0"
"id": "particle.particle-vscode-pack",
"version": "1.13.0"
"id": "particle.particle-vscode-snippets",
"version": "1.13.0"
"id": "particle.particle-vscode-theme",
"version": "1.13.0"
"id": "vsciot-vscode.vscode-arduino",
"version": "0.3.4"
