BDub
August 31, 2023, 2:58pm
144
August 31st 2023: Device OS v5.5.0
This is a release on non-LTS feature development branch (5.x). To learn more about our new LTS release line, read our blog post .
Note: This is a Release and may be used for production .
You can view information about Device OS versions, upgrades and downgrades here .
5.5.0
Highlights
FEATURES
Asset OTA #2668
[M SoM] Platform support #2681
[rtl872x] Experimental WPA3 support #2673
[WiFi] Hidden SSID support #2673
[rtl872x] GPIO drive strength configuration support #2680
ENHANCEMENTS
[WiFi] WiFI interface power state notifications #2669
[rtl872x] Improve SPI1 (P2 / Tracker M) and SPI (M SoM) behavior at 50MHz by changing RXD sample delay #2677
[rtl872x] Improve USB Serial TX performance #2672
[Cellular] Enables UPSV=1 low power mode for R510 when idle for >=9.2s #2674
[rtl872x] Fix logic level overshoot on SPI, I2C, PWM pins #2680
[rtl872x] Revert the QSPI flash speed to 80MHz #2684
Update the key used for validating the ServerMoved signature #2688
[rtl872x] remove the delay in UART flush() #2686
Be sure to read the full collection of release notes Particle Device OS Updates Thread.
BDub
September 26, 2023, 3:21pm
145
September 26th 2023: Device OS v4.2.0
Note: This is a Release and may be used for production . This is the 4th Release in the Device OS release 4.x line (LTS) with critical bugfixes and backports from 5.x release line
To learn more about LTS release line, read our blog post .
4.2.0
ENHANCEMENTS
[services] add long long support to printf/scanf #2694 #2696
[wiring] Add 64-bit String conversions #2693 #2657
[wiring] json: 64-bit support #2695 #2657
BUGFIXES
Fixes clean target for applications with large number of files + P2 PSRAM size calculation issues #2661
[gen3] hal: fixes the issue that UARTE RX may lose data #2698
[quectel] Fixes ncp-client not waiting for modem ready on cold boot #2700
... and other bugfixes and improvements!
BDub
December 8, 2023, 12:25am
146
December 7th 2023: Device OS v5.6.0
5.6.0
FEATURES
[msom] ACM basic support #2689
ENHANCEMENTS
[wiring] Add 64-bit string conversions #2693
[msom] increase NCP baudrate to 921600, doubling throughput #2706
[network] Wiznet Ethernet performance improvements #2708
January 24th 2024: Device OS v5.7.0
5.7.0
Highlights
Allow duplicate advertisements in BLE scan results if requested with BLE.scanWithFilter(BleScanFilter().allowDuplicates(true)) #2718
[P2 / M SoM] Dynamically adjust radio prioritization when both BLE and WiFi are active improving BLE scanning performance #2714
[P2 / M SoM] SPI performance improvements #2728 #2731
[P2 / M SoM] Ethernet performance improvements #2728 #2731
BDub
March 15, 2024, 10:49pm
148
March 15th 2024: Device OS v5.8.0
5.8.0
Highlights
Ledger #2715 #2756
[WiFi] WiFi.setCredentials() with credentials validation #2746 #2754 #2758
[Cellular] Improve BG95 connection speed by only setting nwscanseq if needed #2735
Include IMEI in CTRL_REQUEST_CELLULAR_GET_ICCID control request #2730
Process system tasks while cloud handshake is in progress #2745
