Device OS 5.7.0 Release is available in the Web IDE, Particle CLI and Workbench for (Argon/Boron/B SoM/B5 SoM/Tracker/Tracker M/E SoM X/M SoM/P2).
Released on January 24, 2024
Note: This is a Release and may be used for production.
This is a release on non-LTS feature development branch (5.x). To learn more about our new LTS release line, read our blog post.
Device OS v3.1.x and further releases bring support for 256KB application binaries to all Gen 3 platforms (at that time: Argon, Boron, B SoM, B5 SoM, Tracker). A few important aspects of this change:
- If using standalone Particle CLI installation, make sure it's updated to >= 2.12.0 version, which includes support for 256KB applications.
5.7.0
FEATURES
- Allow duplicates in BLE scan results if requested with
BLE.scanWithFilter(BleScanFilter().allowDuplicates(true))#2718
ENHANCEMENTS
- [P2 / M SoM] BLE: Dynamically adjust radio prioritization when both BLE and WiFi are active improving BLE scanning performance #2714
- ACM
preferred()/prefer()API clean up #2717 - [M SoM] Adjust cloud keep-alive based on network connection #2716
- [M SoM] Enable session resumption #2722
- [P2 / M SoM] SPI performance improvements #2728 #2731
- [P2 / M SoM] Ethernet performance improvements #2728 #2731
BUGFIXES
- [P2 / M SoM] BLE scan results should be filtered for duplicates by default #2718
- Fix OpenOCD FreeRTOS thread list access (
uxTopUsedPriority) #2723 - [Gen 3] BLE: Fix stack overflow in BLE timer callback #2725
- [Cellular] Fixes parsing of MCC/MNC with 00 or 000 MNC #2726
- [P2 / M SoM] Use security type from
JoinNewNetworkrequest to connect to hidden networks #2724 - [build] include alignment into section size calculations #2719
- [P2 / M SoM] SPI slave mode bugfixes #2728 #2731
- [P2 / M SoM] USB TX hold-off mechanism should account for maximum transmit size #2729
- [P2 / M SoM] USB ISR worker thread priority below network threads priorities #2729
INTERNAL
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v5.7.0/particle_device-os@5.7.0.zip
Programming and Debugging
