Particle.publish not working on the Electron
Hi All,
I have 2 Particle Electrons that I have been experimenting with. The devices consistently blink cyan indicating that they are connected to the cloud, and I am able to toggle LEDs or read sensor values over the cloud without issue. The particle console displays a recent last hand shake time and is also able to ping the Electrons.
However, I have been unable to get any form of data to appear in the console for either of the devices.
I am fairly new to Particle so I am reluctant to blame the Particle backend, but I am stumped as to what else the problem could be.
Any suggestions would be greatly appreciated.
Thanks in advance,
Daniel
EDIT/ ADDITION:
I get an error message when trying to publish an event from the console:
The device is definitely connected to the cloud:
Are you using Microsoft Edge by any chance? If so, could you try a different browser? Additionally, could you check if the event shows up in the Particle app?
Hey Moors7,
We are using Chrome, however we just discovered that the issue was with our internal wifi system security, so it is all fixed now!
