Particle PHOTON Red/Blue ligths issue on DEV
Hello everyone!..
I have a problem with the PHOTON. When i going to upload a new code from Particle DEV, the PHOTON give me a Red/Blue ligths at the same time…a do nothing…
All of thesse days i was working normally and there is any problem…
Only i can revert this lights to fading blue, making a reset from the mobile app o uploading the code from de Web Build , (on this way works well…)
Any suggestion?
I think you are seeing the same issue
Yes…i just seen this topic…
From any update, maybe?..
As I said in the linked thread
Dev always builds for the latest available official version (currently 0.5.1), but if your device's system has a lower version the device falls into Safe Mode and should be helped out of that state by the so called Safe-Mode-Healer which doesn't seem to kick in correctly.
So when you flashed your last app code, you got a 0.5.1 app, flashed it to you not-yet updated device and fell into Safe Mode.
You could get out of this via particle update or just flash a simple 0.5.1 sketch via Build which will auto-update your Photon.
After that you can reflash your desired code via Dev again.
Hey ScruffR!
Thanks, tomorrow i will try running this and i will back again with feedback, seens that you have the solution…
