Hello,
I designed a pcb for my particle photon and the board contains a input for a lipo battery and a buck-boost converter which powers up the photon via the 3.3v pin. On the datasheet current draw for 5v is given at an average of 80-100mA with wifi on. Is the current draw if powered through the 3.3v pin the same?
