When using my Particle Argon device each time plug the USB into my laptop it always flashes to connect to the Wifi. I do the usual ‘particle device wifi’ command and it always connects.
However, when i write some code and flash the device the wi-fi connection seem to be lost. I have to keep re-connecting the wifi.
Any ideas why it is doing this? Is there a way so it will always remember and connect to my wifi each time it switches on?
Another question is, when i flash the device and power the device off, is this code still on the device? So say its flashed successfully and i power off. If i reconnect to the Wifi, is there any need to re-flash the device?
Apologies for the silly questions i am very new to all of this.
You can do the following to set your credentials. You can save multiple credentials, too. Typically, I do this when I am going to move a device to a different location which uses a different ssid and password. I do NOT want to be continuously writing these credentials, though. So, I turn off the block of code and re-flash once completed.
// setting credentials
if (1 == 2) { // turn on, flash, turn off and flash again
// Connects to a network secured with WPA2 credentials.
// WiFi.setCredentials(ssid, password);
WiFi.setCredentials("my second ssid", "my second ssid password");
//WiFi.setCredentials("my third ssid", "my third ssid password");
delay(200);
As long you don't reset the creds - either via WiFi.clearCredentials() or the MODE/SETUP button - it will remember them without you needing to do anything else.
