Particle Ethernet FeatherWing with Adafruit OLED 128x32
I would like to use all 3 of the buttons on the Adafruit OLED 128x32. I know that the Ethernet uses D3 and D4 so buttons A and B can’t be used. The Particle Ethernet FeatherWing allows you to rewire these to other pins, but how do I make the change in the firmware, since the Ethernet driver is baked into the Mesh Device OS?
It’s not currently possible to configure Device OS to use different pins for Ethernet FeatherWing control signals.
Got it. Thanks for the quick reply.
