I’ve been trying to set up my particle Electron to connect. I’ve got it connected to the cloud and the Particle IDE is recognizing it however when I put it in DFU mode my computer says it’s trying to install the device drivers for the electron by it never has any luck. It simply shows in the device manager an exclamation point. When I try to manually install the device driver my system can’t find one. I have the Particle CLI installed and am running NodeJS which I’m fairly familiar with. I’m not new to the Photon but I’ve been trying to set up this electron all night. Still no luck. Where can I find the device drivers for this electron so I can get my device manager to assign it a Serial connection? Thanks!
The first hit when searching for "DFU driver":
Thank You Moors7
