These are the messages from the debug software:
clouddebug: press letter corresponding to the command
a - enter APN for 3rd-party SIM card
k - set keep-alive value
c - show carriers at this location
t - run normal tests (occurs automatically after 10 seconds)
starting tests…
turning cellular on…
deviceID=22002f001951343334363036
manufacturer=u-blox
model=SARA-U270
firmware version=23.20
ordering code=SARA-U270-00S-00
IMEI=352253061213236
IMSI=u-blox
ICCID=8934076500002730810
0000022491 [app] INFO: enabling trace logging
attempting to connect to the cellular network…
0000022491 [system] INFO: Sim Ready
0000022492 [system] INFO: ARM_WLAN_WD 1
0000022492
[ Modem::init ] = = = = = = = = = = = = = = =
22.493 AT send 9 "AT+CGSN\r\n"
22.513 AT read UNK 19 "\r\n352253061213236\r\n"
22.523 AT read OK 6 "\r\nOK\r\n"
22.523 AT send 9 "AT+CGMI\r\n"
22.533 AT read UNK 10 "\r\nu-blox\r\n"
22.543 AT read OK 6 "\r\nOK\r\n"
22.543 AT send 9 "AT+CGMM\r\n"
22.553 AT read UNK 13 "\r\nSARA-U270\r\n"
22.563 AT read OK 6 "\r\nOK\r\n"
22.563 AT send 9 "AT+CGMR\r\n"
22.573 AT read UNK 9 "\r\n23.20\r\n"
22.583 AT read OK 6 "\r\nOK\r\n"
22.583 AT send 9 "AT+CCID\r\n"
22.593 AT read + 30 "\r\n+CCID: 8934076500002730810\r\n"
22.604 AT read OK 6 "\r\nOK\r\n"
22.604 AT send 11 "AT+UPSV=1\r\n"
22.614 AT read OK 6 "\r\nOK\r\n"
22.614 AT send 11 "AT+CMGF=1\r\n"
22.624 AT read OK 6 "\r\nOK\r\n"
22.624 AT send 13 "AT+CNMI=2,1\r\n"
22.634 AT read OK 6 "\r\nOK\r\n"
22.634 AT send 9 "AT+CIMI\r\n"
22.644 AT read UNK 19 "\r\n214074300563477\r\n"
22.654 AT read OK 6 “\r\nOK\r\n”
[ Modem::register ] = = = = = = = = = = = = = =
22.654 AT send 10 "AT+CREG?\r\n"
22.665 AT read + 33 "\r\n+CREG: 2,5,“01F8”,“1F5C4FC”,6\r\n"
22.676 AT read OK 6 "\r\nOK\r\n"
22.676 AT send 11 "AT+CGREG?\r\n"
22.686 AT read + 39 "\r\n+CGREG: 2,5,“01F8”,“1F5C4FC”,6,“6C”\r\n"
22.697 AT read OK 6 "\r\nOK\r\n"
22.697 AT send 10 "AT+COPS?\r\n"
22.737 AT read + 26 "\r\n+COPS: 0,0,“STARHUB”,2\r\n"
22.748 AT read OK 6 "\r\nOK\r\n"
22.748 AT send 9 "AT+CNUM\r\n"
22.788 AT read OK 6 "\r\nOK\r\n"
22.788 AT send 8 "AT+CSQ\r\n"
22.798 AT read + 13 "\r\n+CSQ: 5,2\r\n"
22.808 AT read OK 6 “\r\nOK\r\n”
[ Modem::join ] = = = = = = = = = = = = = = = =
22.808 AT send 12 "AT+CGATT=1\r\n"
22.819 AT read OK 6 "\r\nOK\r\n"
22.819 AT send 14 "AT+UPSND=0,8\r\n"
22.829 AT read + 17 "\r\n+UPSND: 0,8,0\r\n"
22.839 AT read OK 6 "\r\nOK\r\n"
22.839 AT send 23 "AT+UPSD=0,7,“0.0.0.0”\r\n"
22.850 AT read OK 6 "\r\nOK\r\n"
22.850 AT send 36 "AT+UPSD=0,1,“spark.telefonica.com”\r\n"
22.861 AT read OK 6 "\r\nOK\r\n"
22.861 AT send 15 "AT+UPSD=0,6,0\r\n"
22.871 AT read OK 6 "\r\nOK\r\n"
22.871 AT send 14 "AT+UPSDA=0,3\r\n"
25.811 AT read OK 6 "\r\nOK\r\n"
25.811 AT send 14 "AT+UPSND=0,0\r\n"
25.821 AT read + 30 "\r\n+UPSND: 0,0,“10.42.166.70”\r\n"
25.832 AT read OK 6 "\r\nOK\r\n"
0000025832 [system] INFO: ARM_WLAN_WD 2
0000025832 [system] INFO: CLR_WLAN_WD 1, DHconnected to the cellular network in 2 milliseconds
connected to cellular network!
25.836 AT send 12 "AT+UDOPN=9\r\n"
25.876 AT read + 23 "\r\n+UDOPN: 2,“STARHUB”\r\n"
25.886 AT read OK 6 "\r\nOK\r\n"
operator name=STARHUB
25.886 AT send 8 "AT+CSQ\r\n"
25.896 AT read + 13 "\r\n+CSQ: 4,3\r\n"
25.906 AT read OK 6 "\r\nOK\r\n"
rssi=-105, qual=3
25.906 AT send 11 "AT+CGED=5\r\n"
25.916 AT read ERR 39 "\r\n+CME ERROR: operation not supported\r\n"
25.917 AT send 11 "AT+CGED=3\r\n"
25.927 AT read + 22 "\r\n+CGED: RAT:“UMTS”,\r\n"
25.937 AT read UNK 63 "\r\nMCC:525, MNC: 5, LAC:01f8, CI:1f5c4fc, DLF:10613, ULF:9663\r\n"
25.948 AT read OK 6 "\r\nOK\r\n"
0000025948 [app] INFO: service rat=UMTS mcc=525, mnc=5, lac=1f8 ci=1f5c4fc band=UMTS 2100 rssi=0 dlf=10613 ulf=9663
0000025948 25.949 AT send 20 "AT+UPING=“8.8.8.8”\r\n"
25.960 AT read OK 6 "\r\nOK\r\n"
ping addr 8.8.8.8=1
25.960 AT send 31 "AT+UDNSRN=0,“device.spark.io”\r\n"
device.spark.io=0.0.0.0
connecting to cloud
0000035971 [system] INFO: Cloud: connecting
0000035971 [system] INFO: Cloud: conn0000035972 [system] INFO: Read Server Address = type:1,domain:$i 35.973 AT send 56 "AT+UDNSRN=0,“22002f001951343334363036.udp.particle.io”\r\n"
65.985 AT send 56 "AT+UDNSRN=0,“22002f001951343334363036.udp.particle.io”\r\n"
87.886 AT read ERR 9 "\r\nERROR\r\n"
87.887 AT send 56 "AT+UDNSRN=0,“22002f001951343334363036.udp.particle.io”\r\n"
87.888 AT read + 14 "\r\n+CIEV: 2,0\r\n"
87.899 AT read + 14 "\r\n+CIEV: 2,1\r\n"
87.909 AT read + 14 "\r\n+CIEV: 2,0\r\n"
87.919 AT read + 14 "\r\n+CIEV: 2,1\r\n"
87.929 AT read + 14 "\r\n+CIEV: 2,0\r\n"
87.939 AT read + 14 "\r\n+CIEV: 2,1\r\n"
87.949 AT read + 14 "\r\n+CIEV: 2,0\r\n"
87.959 AT read + 14 "\r\n+CIEV: 2,1\r\n"
0000117890 [system] ERROR: Cloud: unable to resolve IP for 22002f001951343334363036.udp.particle.io
0000117890 [system] ERROR: 0000117891 [system] TRACE: Internet test socket
On first socketSocket use, free all open sockets
117.892 AT send 15 "AT+USOCTL=0,1\r\n"
127.902 AT send 15 "AT+USOCTL=1,1\r\n"
137.912 AT send 15 “AT+USOCTL=2,1\r\n"
147.922 AT send 15 “AT+USOCTL=3,1\r\n"
149.322 AT read ERR 9 “\r\nERROR\r\n"
149.322 AT send 15 “AT+USOCTL=4,1\r\n"
149.322 AT read + 35 “\r\n+UUPING: 1,32,””,“8.8.8.8”,0,-1\r\n"
149.334 AT read + 35 “\r\n+UUPING: 2,32,””,“8.8.8.8”,0,-1\r\n"
149.345 AT read + 35 “\r\n+UUPING: 3,32,””,“8.8.8.8”,0,-1\r\n"
149.356 AT read + 35 “\r\n+UUPING: 4,32,””,“8.8.8.8”,0,-1\r\n"
149.367 AT read + 14 "\r\n+CIEV: 2,0\r\n"
149.377 AT read + 14 "\r\n+CIEV: 2,1\r\n"
149.387 AT read + 14 "\r\n+CIEV: 2,0\r\n"
149.397 AT read + 14 "\r\n+CIEV: 2,1\r\n"
149.407 AT read + 14 "\r\n+CIEV: 2,0\r\n"
149.417 AT read + 14 "\r\n+CIEV: 2,1\r\n"
149.427 AT read + 14 "\r\n+CIEV: 2,0\r\n"
149.437 AT read ERR 37 "\r\n+CME ERROR: operation not allowed\r\n"
149.438 AT send 15 "AT+USOCTL=5,1\r\n"
149.448 AT read ERR 37 "\r\n+CME ERROR: operation not allowed\r\n"
149.449 AT send 15 "AT+USOCTL=6,1\r\n"
149.459 AT read ERR 37 "\r\n+CME ERROR: operation not allowed\r\n"
socketSocket(TCP)
149.460 AT send 12 "AT+USOCR=6\r\n"
149.470 AT read + 13 "\r\n+USOCR: 0\r\n"
149.480 AT read OK 6 "\r\nOK\r\n"
Socket 0: handle 0 was created
0000149480 [system] TRACE: socketed testSocket=0
0000149480 [system] TRACE: Connect Attempt
socketConnect(0,port:53)
149.481 AT send 25 "AT+USOCO=0,“8.8.8.8”,53\r\n"
0000159492 [system] TRACE: socket_connect()=fail
0000159492 [system] TRACE: Close
socketClose(0)
159.492 AT send 12 "AT+USOCL=0\r\n"
168.003 AT read ERR 9 "\r\nERROR\r\n"
168.003 AT send 9 "AT+CEER\r\n"
168.003 AT read + 14 "\r\n+CIEV: 2,1\r\n"
168.014 AT read + 14 "\r\n+CIEV: 2,0\r\n"
168.024 AT read + 32 "\r\n+CEER: “No report available”\r\n"
168.034 AT read OK 6 "\r\nOK\r\n"
socketFree(0)
0000168034 [system] WARN: Internet available, Cloud not reachable!
00000000168035 [system] INFO: Cloud: connecting
0000168035 [system]0000168036 [0000168036 [system] INFO: Read Server Address = type:1,domain:$i 168.037 AT send 56 “AT+UDNSRN=0,“22002f001951343334363036.udp.particle.io”\r\n”
