I have setup an Electron today, it connected and all was good. I then flashed it OTA with a program that I am currently using on an existing Electron, with no changes. It never reconnected to the cloud. I have tried then flashing it again from the CLI, I have tried safe mode, I have tried flashing it via the CLI with Tinker and update and then flash again. Nothing seems to work. I have also deactivated the sim and reactivated it.
I also tried particle keys doctor followed by particle keys server, this has not worked either. Lastly I flashed it with a Tinker Debug program and have the following log:
259.223 AT read OK 6 "\r\nOK\r\n"
259.223 AT send 12 "AT+CGREG=2\r\n"
259.233 AT read OK 6 "\r\nOK\r\n"
259.233 AT send 11 "AT+CREG=2\r\n"
259.243 AT read OK 6 "\r\nOK\r\n"
259.243 AT send 10 "AT+CREG?\r\n"
259.253 AT read + 14 "\r\n+CREG: 2,0\r\n"
259.263 AT read OK 6 "\r\nOK\r\n"
259.263 AT send 11 "AT+CGREG?\r\n"
259.273 AT read + 15 "\r\n+CGREG: 2,0\r\n"
259.283 AT read OK 6 "\r\nOK\r\n"
274.283 AT send 10 "AT+CREG?\r\n"
275.843 AT read + 12 "\r\n+CREG: 4\r\n"
275.853 AT read + 13 "\r\n+CGREG: 4\r\n"
275.863 AT read + 14 "\r\n+CIEV: 3,0\r\n"
275.873 AT read + 14 "\r\n+CIEV: 7,0\r\n"
275.883 AT read + 14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
275.893 AT read + 14 "\r\n+CREG: 2,4\r\n"
275.903 AT read OK 6 "\r\nOK\r\n"
275.903 AT send 11 "AT+CGREG?\r\n"
278.383 AT read + 15 "\r\n+CGREG: 2,4\r\n"
278.393 AT read OK 6 "\r\nOK\r\n"
293.393 AT send 10 "AT+CREG?\r\n"
293.393 AT read + 14 "\r\n+CIEV: 2,1\r\n"
293.403 AT read + 31 "\r\n+CREG: 5,\"5250\",\"2DD073C\",2\r\n"
293.413 AT read + 37 "\r\n+CGREG: 5,\"5250\",\"2DD073C\",2,\"01\"\r\n"
293.424 AT read + 14 "\r\n+CIEV: 3,1\r\n"
293.434 AT read + 14 "\r\n+CIEV: 7,1\r\n"
293.444 AT read + 14 "\r\n+CIEV: 9,2\r\n"
CIEV matched: 9,2
294.944 AT read + 33 "\r\n+CREG: 2,5,\"5250\",\"2DD073C\",2\r\n"
294.954 AT read OK 6 "\r\nOK\r\n"
294.954 AT send 11 "AT+CGREG?\r\n"
294.964 AT read + 39 "\r\n+CGREG: 2,5,\"5250\",\"2DD073C\",2,\"01\"\r\n"
294.975 AT read OK 6 "\r\nOK\r\n"
294.975 AT send 10 "AT+COPS?\r\n"
295.015 AT read + 33 "\r\n+COPS: 0,0,\"Telstra Mobile\",2\r\n"
295.025 AT read OK 6 "\r\nOK\r\n"
295.025 AT send 9 "AT+CNUM\r\n"
295.065 AT read OK 6 "\r\nOK\r\n"
295.065 AT send 8 "AT+CSQ\r\n"
295.075 AT read + 13 "\r\n+CSQ: 7,6\r\n"
295.085 AT read OK 6 "\r\nOK\r\n"
[ Modem::join ] = = = = = = = = = = = = = = = =
295.085 AT send 12 "AT+CGATT=1\r\n"
295.096 AT read OK 6 "\r\nOK\r\n"
295.096 AT send 14 "AT+UPSND=0,8\r\n"
295.106 AT read + 17 "\r\n+UPSND: 0,8,0\r\n"
295.116 AT read OK 6 "\r\nOK\r\n"
295.116 AT send 23 "AT+UPSD=0,7,\"0.0.0.0\"\r\n"
295.126 AT read OK 6 "\r\nOK\r\n"
295.126 AT send 36 "AT+UPSD=0,1,\"spark.telefonica.com\"\r\n"
295.137 AT read OK 6 "\r\nOK\r\n"
295.137 AT send 15 "AT+UPSD=0,6,0\r\n"
295.147 AT read OK 6 "\r\nOK\r\n"
295.147 AT send 14 "AT+UPSDA=0,3\r\n"
306.787 AT read ERR 39 "\r\n+CME ERROR: PDP activation rejected\r\n"
306.787 AT send 15 "AT+UPSD=0,6,1\r\n"
306.788 AT read + 14 "\r\n+CIEV: 2,0\r\n"
306.799 AT read + 12 "\r\n+CREG: 2\r\n"
306.809 AT read + 13 "\r\n+CGREG: 2\r\n"
306.819 AT read + 14 "\r\n+CIEV: 3,0\r\n"
306.829 AT read + 14 "\r\n+CIEV: 7,0\r\n"
306.839 AT read + 14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
306.849 AT read OK 6 "\r\nOK\r\n"
306.849 AT send 14 "AT+UPSDA=0,3\r\n"
379.319 AT read OK 6 "\r\nOK\r\n"
379.319 AT send 14 "AT+UPSND=0,0\r\n"
379.319 AT read + 12 "\r\n+CREG: 0\r\n"
379.330 AT read + 13 "\r\n+CGREG: 0\r\n"
379.340 AT read + 12 "\r\n+CREG: 2\r\n"
379.350 AT read + 13 "\r\n+CGREG: 2\r\n"
379.360 AT read + 12 "\r\n+CREG: 0\r\n"
379.370 AT read + 13 "\r\n+CGREG: 0\r\n"
379.380 AT read + 12 "\r\n+CREG: 2\r\n"
379.390 AT read + 13 "\r\n+CGREG: 2\r\n"
379.400 AT read + 31 "\r\n+CREG: 5,\"5250\",\"2DD073C\",2\r\n"
379.410 AT read + 37 "\r\n+CGREG: 5,\"5250\",\"2DD073C\",2,\"01\"\r\n"
379.421 AT read + 14 "\r\n+CIEV: 3,1\r\n"
379.431 AT read + 14 "\r\n+CIEV: 7,1\r\n"
379.441 AT read + 14 "\r\n+CIEV: 9,2\r\n"
CIEV matched: 9,2
379.451 AT read + 14 "\r\n+CIEV: 2,1\r\n"
379.461 AT read + 29 "\r\n+UPSND: 0,0,\"10.44.11.63\"\r\n"
379.471 AT read OK 6 "\r\nOK\r\n"
0000379471 [system] INFO: ARM_WLAN_WD 2
000030000379472 [system] INFO: Cloud: connecting
0000379472 [system]0000379472 [system] TRACE0000379473 [system] INFO: Read Server Address = type:1,domain:$i 379.474 AT send 56 "AT+UDNSRN=0,\"280054000951343334363138.udp.particle.io\"\r\n"
409.486 AT send 56 "AT+UDNSRN=0,\"280054000951343334363138.udp.particle.io\"\r\n"
439.498 AT send 56 "AT+UDNSRN=0,\"280054000951343334363138.udp.particle.io\"\r\n"
442.909 AT read ERR 9 "\r\nERROR\r\n"
0000442910 [system] ERROR: Cloud: unable to resolve IP for 280054000951343334363138.0000442911 [system] TRACE: Internet test socket
socketSocket(TCP)
442.912 AT send 12 "AT+USOCR=6\r\n"
442.912 AT read + 12 "\r\n+CREG: 2\r\n"
442.923 AT read + 13 "\r\n+CGREG: 2\r\n"
442.933 AT read + 12 "\r\n+CREG: 0\r\n"
442.943 AT read + 13 "\r\n+CGREG: 0\r\n"
442.953 AT read + 31 "\r\n+CREG: 5,\"5250\",\"2DD073F\",2\r\n"
442.963 AT read + 37 "\r\n+CGREG: 5,\"5250\",\"2DD073F\",2,\"01\"\r\n"
442.974 AT read + 12 "\r\n+CREG: 2\r\n"
442.984 AT read + 13 "\r\n+CGREG: 2\r\n"
442.994 AT read + 31 "\r\n+CREG: 5,\"5250\",\"2DD073C\",2\r\n"
443.004 AT read + 37 "\r\n+CGREG: 5,\"5250\",\"2DD073C\",2,\"01\"\r\n"
443.015 AT read + 12 "\r\n+CREG: 2\r\n"
443.025 AT read + 13 "\r\n+CGREG: 2\r\n"
443.035 AT read + 14 "\r\n+CIEV: 2,0\r\n"
443.045 AT read + 14 "\r\n+CIEV: 3,0\r\n"
443.055 AT read + 14 "\r\n+CIEV: 7,0\r\n"
443.065 AT read + 14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
0000443065 TRACE: GPRS WD Set 15000
443.075 AT read + 14 "\r\n+CIEV: 3,1\r\n"
443.085 AT read + 14 "\r\n+CIEV: 7,1\r\n"
443.095 AT read + 14 "\r\n+CIEV: 9,2\r\n"
CIEV matched: 9,2
0000443095 TRACE: GPRS WD Cleared, was 0
443.105 AT read + 14 "\r\n+CIEV: 2,1\r\n"
443.115 AT read + 14 "\r\n+CIEV: 3,0\r\n"
443.125 AT read + 14 "\r\n+CIEV: 7,0\r\n"
443.135 AT read + 14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
0000443135 TRACE: GPRS WD Set 15000
443.145 AT read + 14 "\r\n+CIEV: 3,1\r\n"
443.155 AT read + 14 "\r\n+CIEV: 7,1\r\n"
443.165 AT read + 14 "\r\n+CIEV: 9,2\r\n"
CIEV matched: 9,2
0000443165 TRACE: GPRS WD Cleared, was 0
443.175 AT read + 14 "\r\n+CIEV: 3,0\r\n"
443.185 AT read + 14 "\r\n+CIEV: 7,0\r\n"
443.195 AT read + 14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
0000443195 TRACE: GPRS WD Set 15000
443.205 AT read + 13 "\r\n+USOCR: 0\r\n"
443.215 AT read OK 6 "\r\nOK\r\n"
Socket 0: handle 0 was created
0000443215 [system] TRACE: socketed testSocket=0
0000443215 [system] TRACE: Connect Attempt
socketConnect(0,port:53)
443.216 AT send 25 "AT+USOCO=0,\"8.8.8.8\",53\r\n"
0000453226 [system] TRACE: socket_connect()=fail
0000453226 [system] TRACE: Close
socketClose(0)
453.226 AT send 12 "AT+USOCL=0\r\n"
461.767 AT read ERR 9 "\r\nERROR\r\n"
461.767 AT send 9 "AT+CEER\r\n"
0000461767 TRACE: GPRS WD Cleared, was 0
0000461768 [system] INFO: ARM_WLAN_WD 3
0000461768 [system] INFO: ARM_WLAN 461.778 AT read + 32 "\r\n+CEER: \"No report available\"\r\n"
461.788 AT read OK 6 "\r\nOK\r\n"
socketFree(0)
0000461788 [system] WARN: Internet available, Cloud not reachable!
0000461788 [system] WARN: Intern0000461789 [system] WARN: Ha0000461789 [system] INFO: Sim Ready
0000461790 [system] INFO: ARM_WLAN_WD 1
0000461790 [s
[ Modem::init ] = = = = = = = = = = = = = = =
461.790 AT send 9 "AT+CGSN\r\n"
461.811 AT read UNK 19 "\r\n353162071300355\r\n"
461.821 AT read OK 6 "\r\nOK\r\n"
461.821 AT send 9 "AT+CGMI\r\n"
461.841 AT read UNK 10 "\r\nu-blox\r\n"
461.851 AT read OK 6 "\r\nOK\r\n"
461.851 AT send 9 "AT+CGMM\r\n"
461.851 AT read + 31 "\r\n+CREG: 5,\"5250\",\"2DD073F\",2\r\n"
461.862 AT read + 37 "\r\n+CGREG: 5,\"5250\",\"2DD073F\",2,\"01\"\r\n"
461.873 AT read + 14 "\r\n+CIEV: 3,1\r\n"
461.883 AT read + 14 "\r\n+CIEV: 7,1\r\n"
461.893 AT read + 14 "\r\n+CIEV: 9,2\r\n"
CIEV matched: 9,2
461.903 AT read UNK 13 "\r\nSARA-U260\r\n"
461.913 AT read OK 6 "\r\nOK\r\n"
461.913 AT send 9 "AT+CGMR\r\n"
461.923 AT read UNK 9 "\r\n23.20\r\n"
461.933 AT read OK 6 "\r\nOK\r\n"
461.933 AT send 9 "AT+CCID\r\n"
461.943 AT read + 30 "\r\n+CCID: 8934076500002735330\r\n"
461.953 AT read OK 6 "\r\nOK\r\n"
461.953 AT send 11 "AT+UPSV=1\r\n"
461.963 AT read OK 6 "\r\nOK\r\n"
461.963 AT send 11 "AT+CMGF=1\r\n"
461.973 AT read OK 6 "\r\nOK\r\n"
461.973 AT send 13 "AT+CNMI=2,1\r\n"
461.983 AT read OK 6 "\r\nOK\r\n"
461.983 AT send 9 "AT+CIMI\r\n"
461.993 AT read UNK 19 "\r\n214074300563929\r\n"
462.003 AT read OK 6 "\r\nOK\r\n"
[ Modem::register ] = = = = = = = = = = = = = =
462.003 AT send 10 "AT+CREG?\r\n"
462.014 AT read + 33 "\r\n+CREG: 2,5,\"5250\",\"2DD073F\",2\r\n"
462.024 AT read OK 6 "\r\nOK\r\n"
462.024 AT send 11 "AT+CGREG?\r\n"
462.034 AT read + 39 "\r\n+CGREG: 2,5,\"5250\",\"2DD073F\",2,\"01\"\r\n"
462.045 AT read OK 6 "\r\nOK\r\n"
462.045 AT send 10 "AT+COPS?\r\n"
462.045 AT read + 14 "\r\n+UUSOCL: 0\r\n"
Socket -1: handle 0 closed by remote host
462.086 AT read + 33 "\r\n+COPS: 0,0,\"Telstra Mobile\",2\r\n"
462.097 AT read OK 6 "\r\nOK\r\n"
462.097 AT send 9 "AT+CNUM\r\n"
462.137 AT read OK 6 "\r\nOK\r\n"
462.137 AT send 8 "AT+CSQ\r\n"
462.147 AT read + 13 "\r\n+CSQ: 8,6\r\n"
462.157 AT read OK 6 "\r\nOK\r\n"
462.157 AT send 12 "AT+CGATT=1\r\n"
462.168 AT read OK 6 "\r\nOK\r\n"
462.168 AT send 14 "AT+UPSND=0,8\r\n"
462.178 AT read + 17 "\r\n+UPSND: 0,8,1\r\n"
462.188 AT read OK 6 "\r\nOK\r\n"
462.188 AT send 14 "AT+UPSND=0,0\r\n"
462.198 AT read + 29 "\r\n+UPSND: 0,0,\"10.44.11.63\"\r\n"
462.208 AT read OK 6 "\r\nOK\r\n"
0000462208 [system] INFO: ARM_WLAN_WD 2
0000462208 [system] INFO: C0000462209 [system] INFO: Cloud: connecting
0000462209 [system]0000462209 [system] TRACE: sparkSocket Now =-1
0000462210 [system] INFO: Read Server Address = type:1,domain:$id.u 462.211 AT send 56 "AT+UDNSRN=0,\"280054000951343334363138.udp.particle.io\"\r\n"
492.223 AT send 56 "AT+UDNSRN=0,\"280054000951343334363138.udp.particle.io\"\r\n"
522.235 AT send 56 "AT+UDNSRN=0,\"280054000951343334363138.udp.particle.io\"\r\n"
523.006 AT read ERR 9 "\r\nERROR\r\n"
0000523007 [system] ERROR: Cloud: unable to resolve IP for 280054000951343334363138.udp.particle.io
0000523007 [system] ERROR: 00005230000523008 [system] WARN: Resetting WLAN due to 2 failed connect0000523009 [system] TRACE: Internet test socket
socketSocket(TCP)
523.009 AT send 12 "AT+USOCR=6\r\n"
523.010 AT read + 12 "\r\n+CREG: 2\r\n"
523.020 AT read + 13 "\r\n+CGREG: 2\r\n"
523.030 AT read + 12 "\r\n+CREG: 0\r\n"
523.040 AT read + 13 "\r\n+CGREG: 0\r\n"
523.050 AT read + 31 "\r\n+CREG: 5,\"5250\",\"2DD073F\",2\r\n"
523.060 AT read + 37 "\r\n+CGREG: 5,\"5250\",\"2DD073F\",2,\"01\"\r\n"
523.071 AT read + 14 "\r\n+CIEV: 2,0\r\n"
523.081 AT read + 14 "\r\n+CIEV: 3,0\r\n"
523.091 AT read + 14 "\r\n+CIEV: 7,0\r\n"
523.101 AT read + 14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
0000523101 TRACE: GPRS WD Set 15000
523.111 AT read + 14 "\r\n+CIEV: 3,1\r\n"
523.121 AT read + 14 "\r\n+CIEV: 7,1\r\n"
523.131 AT read + 14 "\r\n+CIEV: 9,2\r\n"
CIEV matched: 9,2
0000523131 TRACE: GPRS WD Cleared, was 0
523.141 AT read + 14 "\r\n+CIEV: 2,1\r\n"
523.151 AT read + 13 "\r\n+USOCR: 0\r\n"
523.161 AT read OK 6 "\r\nOK\r\n"
0000523161 [system] TRACE: socketed testSocket=0
00005socketConnect(0,port:53)
523.162 AT send 25 "AT+USOCO=0,\"8.8.8.8\",53\r\n"
0000533172 [system] TRACE: socket_connect()=fail
0000533172 [system] TRACE: Close
socketClose(0)
533.172 AT send 12 "AT+USOCL=0\r\n"
541.713 AT read ERR 9 "\r\nERROR\r\n"
541.713 AT send 9 "AT+CEER\r\n"
541.723 AT read + 32 "\r\n+CEER: \"No report available\"\r\n"
541.733 AT read OK 6 "\r\nOK\r\n"
socketFree(0)
0000541733 [system] WARN: Internet available, Cloud not reachable!
00000000541734 [system] WARN: Resetting WLAN due to SPARK_WLAN_RESET
[ Modem::disconnect ] = = = = = =
541.735 AT send 14 "AT+UPSDA=0,4\r\n"
542.406 AT read OK 6 "\r\nOK\r\n"
[ Modem::detach ] = = = = = = = = = = = = = = =
542.406 AT send 12 "AT+CGATT=0\r\n"
542.407 AT read + 14 "\r\n+UUSOCL: 0\r\n"
544.717 AT read OK 6 "\r\nOK\r\n"
544.717 AT send 12 "AT+CGATT=0\r\n"
544.718 AT read + 13 "\r\n+CGREG: 0\r\n"
544.728 AT read + 14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
544.738 AT read OK 6 "\r\nOK\r\n"
[ Modem::powerOff ] = = = = = = = = = = = = = =
544.738 AT send 12 "AT+CPWROFF\r\n"
548.969 AT read OK 6 "\r\nOK\r\n"
[ Modem::powerOn ] = = = = = = = = = = = = = =
549.279 AT send 4 "AT\r\n"
550.599 AT send 4 "AT\r\n"
551.919 AT send 4 "AT\r\n"
553.239 AT send 4 "AT\r\n"
553.249 AT read UNK 3 "AT\r"
553.259 AT read OK 6 "\r\nOK\r\n"
553.469 AT send 7 "AT E0\r\n"
553.479 AT read UNK 6 "AT E0\r"
^CTerminate batch job (Y/N)? y
