Particle Dev updates?
Continuing the discussion from [SOLVED] Blynk library causes panic in certain situations on 0.5.0rc1:
So, this entire linked thread (and probably not the first, or last) was caused (in small part) by Particle Dev not providing a means to select a target firmware version, so the whole build system defaults to the current stable, even when the target device is running something different. Are there any plans to update Particle Dev soon, and add a feature like this? It’s also using a very old version of the Atom core…
Hi @legoguy, we plan to work more on Particle Dev next sprint (starting next week). Currently we were focused on improving Build but didn’t forget about Dev :slight_smile:
Thanks for the update, @suda! Much appreciated, I can’t wait to see how it improves!
hoping to see an update soon that supports linter!
Hi, seems like the update you’ve been waiting for just arrived! I’m using Particle Dev with Atom 1.7.3 today :smile:
i downloaded from that link and hit setup. It showed the splash screen showing installing and opened the old version.
