It took awhile for me to setup the particle-cli but after figuring out how to set it up behind a proxy I could login in using the command line. Now I want to use the Particle DEV, however it can’t select my Particle Electron. It just continuously looks for devices. I tried typing my device ID and device name too but it says no devices available.
On a side note, I can’t directly login into my account via DEV, the only way I can log on into the DEV is through the command line. I get “Error: connect ETIMEDOUT:” with an ip and port. I am thinking since this is a web based IDE I am going to run into the same proxy problem as before.
