Particle cli stopped working Win8
It was working just this morning.
Is this a side effect of the new release? I found this in AppData/Local/particle/error.log
2017/01/23 13:15:55 Updating CLI…
2017/01/23 13:17:37 done. Updated 1 package.
Now when I run particle I get no output.
Thanks for reporting. @jvanier are you able to take a look at this?
I’ll take a look.
I ended up uninstalling the CLI and reinstalling.
reinstalling via the windows installer linked in the ref page did not fix it
https://binaries.particle.io/cli/installer/windows/ParticleCLISetup.exe
reinstalling via node.js worked:
npm install -g particle-cli
I release a new revision of the CLI package that fixes this issue. If you installed the CLI through the Windows installer you can force an update with particle update-cli (this won’t work if installed through npm).
[Edit: clarified what I meant]
Not sure what you mean - the CLI does not recognize that command: particle update-cli
I updated to 1.19.1 via npm install.
Ah. Your clarification explains a bit. I lost the particle update-cli command when I reinstalled via npm.
I can only confirm the same issue on Win10. Yesterday out of a sudden particle.exe refused to work. particle update-cli helped.
